Soyo SY-71S2 Cap Voltage Question
  • Howie
    • Dec 2004
    • 31
    Replacing some caps on this board which was bought new about 2 years ago. Most all were Wendell's and it has 2 leaking and 4 domed.
    Two of the larger leaking caps (3300 uf 10v) i replaced with Rubycons of the same value, and alot of 1000 uf 6.3's have been replaced already, but i have about four (1000uf 10v) caps that are the same size as the 6.3's and very close together above the cpu socket. I have enough 6.3 Rubycons on hand to replace these and they are the same size as the old 10v's.
    I was wanting to ask if the 10v caps can be replaced with 6.3v caps ?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Soyo SY-71S2 Cap Voltage Question
    check the voltage with a multimeter, that will give you a definitive answer...
    Ludicrous gibs!
    • Howie
      • Dec 2004
      • 31
      Thanks for the reply. I have a few 10v Nichicons around, but there to big to fit in this area.
      • yanz
        • Nov 2004
        • 910
        i bet it will be ok to use those 6.3v caps. but better be safe than sorry...
        just curious, what rubycon caps series do you use?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Loretto
          Samsung SMPS BN44-00339A
          by Loretto
          this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
          I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
          I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
          I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
          03-29-2025, 08:30 AM
        • Loretto
          by Loretto
          03-28-2025, 10:28 AM
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
