Dell Dimension 2400 No Post
  • bigbeark
    • Jan 2010
    • 661
    I have my son's old Dell Dimension 2400, which stopped posting last year.
    All caps are Rubycon and none are bulged. ESR tests fine.
    I have removed the board from the case and using my Post Card I observe there is no display of Post Codes at all!
    The board does power up and that IBM heatsink/fan runs at max speed.
    I am thinking that one or more of the MOSFETS is open circuit or grounded.
    There are six in total, three on each side of the L-shaped heatsink. It looks like I can remove the heatsink by removing the screw that atttach the MOSFETS to the heatsink.
    Can anyone offer advice on how to test these MOSFETS or are they likely the problem at all? The MOSFETS are labelled 70L02P and 408401.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell Dimension 2400 No Post
    Originally posted by bigbeark
    I
    I do a simple, in circuit, resistance test between S-G, S-D, and G-D. Any reading under 30 ohms suggests a short and the component should be desoldered and verified out of circuit.
    Others have done it this way.
    http://www.4qdtec.com/mostest.html
    --- begin sig file ---
    --- end sig file ---
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • SwedishDiesel
      Dell Dimension PSU Compatibility - B110 PSU in 4550
      by SwedishDiesel
      Howdy folks,
      I've risen from the grave to ask more questions about old obsolete Dells.
      I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
      The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
      12-18-2022, 06:58 PM
      Dell Dimension 8200 Schematic
      LA-1221...
      10-04-2024, 07:48 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
