ABit VP-6 will not post...about 34 months old
  • MNEyeDoc
    • Feb 2004
    First post...I have emailed...you, TC, I think...
    Well, yesterday evening working on my computer and *POOF* the monitor goes colored pixels/colored snow. CTRL-ALT-DEL does no good...reset does no good...have to power down using the front panel button. At the time of the *POOF* noticed an acrid burning smell...Tried to reboot, power supply fans came on, case fans came on...bad smell came...but no POST. Tried multiple times, no POST. Measured +12V output, about +7 V. Bought a new Power supply (only 450 W, had been using 500 W). Still no POST, but now even the power supply fans will not power up. Front panel power button not working...Red light on the VP-6 comes on, though. So, being a member of www.VP-6.com, I knew about the bad cap issue. I removed the Motherboard, and the caps LOOK fine...but wait...some of the smaller caps have bulged tops, so I figure this is the problem, and now I have been bit by the "Bad Cap" bug. So, I think the motherboard needs the repairs mentioned in the VP-6 project. I am not an electronic tech, so...perhaps...this repair can be effected? As I mentioned, I have emailed and also filled out a quote request, I am just awaiting a reply. I also wanted to post here to offer you a public thanks for this site--I know a little about the time it must take out of your day. Very much appreciated.
    Well, here's to hoping my Motherboard can be salvaged!!
    Best regards,
    MNEyeDoc
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    the poof was likely a cap venting.
    good chance a recap will bring it back.
    tc or i can do it if soldering is over your head.
    can you post pics of the bulging ones?
    • emil_t
      RTX3090 working fine but fans not spinning
      by emil_t
      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
      04-12-2024, 06:54 AM
    • b-slayer
      Asus Strix-G15-G513RM fans don't work
      by b-slayer
      I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
      The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
      (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
      (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
      ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
      09-04-2025, 04:58 AM
    • JayPoorJay
      Hot Water Rad - A Few ECU Fans and a Timer Switch
      by JayPoorJay
      Good Afternoon, Good People.
      I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
      I REALLY would appreciate y'alls help.
      This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
      10-29-2024, 12:54 PM
    • Foetuss
      Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
      by Foetuss
      Hi all
      Hope this is in the correct place.
      I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
      Could use some double checking to see if I'm not doing something stupid .
      Pictures of the boards are attached.
      What I will be replacing with what : (planned)
      Soltek Golden ::
      4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
      6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
      01-18-2025, 11:44 AM
    • sda sad
      my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
      by sda sad
      Hope this is the right place, someone can help me.
      My laptop started having a really strange problem....
      When I turn it on the fans start working at a crazy rate and with random breaks...
      They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
      And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
      The model of the computer:
      Xiaomi Notebook Pro X 15 OLED (A30)
      04-23-2024, 09:55 AM
