Pls help identify this toasted componet on an AGP card.
  • pegasus
    • Feb 2006
    • 4
    I have a faulty CANICON 1000mF 6.3V cap on this card, "MilkyWay" GF4Ti4200 128MB AGP Card, with a burnt component.
    I can't find a matched part at local shops, anyone can suggest an alternative or replacement part?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Pls help identify this toasted componet on an AGP card.
    looks like a completely melted fet, whaddya think about a replacement guys
    • Rainbow
      • Aug 2005
      • 1375
      It MIGHT (and also might not) be the same as the one next to it.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i was looking at a few designs. looks most similar to the msi. i think it is the same as the unit next to it.
        what to do?
        - find someone with the same card and get them to read what is written on their fet. (might be difficult, it is an off brand which i have not heard of before.
        - replace with the same fet or similar specs as the unit next to it and pray.
        pegasus, is there two the same at the other end of the board?
        • Chris1992
          • Apr 2005
          • 561
          the FET above toasted one appears to be an ON Semiconductor part. I've heard of this brand, they're in the Digikey catalog.
          The great capacitor showdown!
          • Mustang
            • Dec 2003
            • 203
            That's one strange looking AGP card.
            • pegasus
              • Feb 2006
              • 4
              I can't tell from original damaged FET because it is incomplete and all marks just gone.
              Will a simply transplant of FETs from other spoilted GF4 cards fix this? Perhaps I have better luck if I replace a pair?
              It is a card friend bought from HK. I don't think I can get another one for reference now.
              • Chris1992
                • Apr 2005
                • 561
                possibly. Pls post a pic of the entire card.
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  • USA, Unsure of Planet
                  On Semiconductor was formed when Motorola spun off their discretes and low profit ICs (older linear ICs, 4000- and 4500- series CMOS, etc.).
                  PeteS in CA
                  • japlytic
                    • Oct 2005
                    • 2086
                    I did a search on their website for "*D30*", and when I looked at the datasheet, the markings (other than the date code) corresponded to a D30N02 https://cdn.badcaps-static.com/pdfs/...a54062dbb1.pdf
                    • Christos Tsiligiannis
                      Marian Trace Alpha sound card repair help
                      by Christos Tsiligiannis
                      Hello to the forum.
                      My name is Christos, I am new to the forum here and i am posting from Greece.
                      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                      So i tried asking for a schematic from the company and they would not give me one. Instead they...
                      11-18-2024, 05:26 AM
                    • Kemer
                      Graphics Card mounting frame
                      by Kemer
                      Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                      As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                      I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                      What worries me right now is the possibility that...
                      09-14-2024, 08:57 AM
                      HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                      This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                      09-06-2024, 08:30 AM
                    • FZG
                      EVGA Nu Audio Sound Card - Not Working
                      by FZG
                      I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                      The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                      I found...
                      03-07-2025, 11:44 AM
                    • benwaterson
                      Gigabyte Aorus 1080ti - card not initialising
                      by benwaterson
                      Hi there.
                      Have searched various forums but haven't come across the exact issue I am having.
                      Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                      I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                      Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                      02-05-2022, 11:42 AM
