aopen ak73.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    aopen ak73.
    all rubycon yxg but the 2 lelon on vrm input.
    what was saved doing this?
  • Chris1992
    • Apr 2005
    • 561
    Re: aopen ak73.
    yecch. what brand of fan is on the CPU heatsink? looks like either panaflo or delta.
    The great capacitor showdown!
    • Oklahoma Wolf
      • Dec 2005
      • 353
      Re: aopen ak73.
      I'm still asking the same question of my AK79G-Max's original Lelon/Chemicon combination
      • Chris1992
        • Apr 2005
        • 561
        Re: aopen ak73.
        I think like $0.10 was saved. If that.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: aopen ak73.
          not sure of the fan.
          psu was bad too and cust declined in favor of a replacement system we had.
          psu is aopen made by fsp and full of exploded jamicons.
          • Chris1992
            • Apr 2005
            • 561
            Re: aopen ak73.
            yuck. Pity those great Fortron PSUs fail b/c of caps.
            • randmusr
              Internal images saved here have disappeared
              by randmusr
              Is there a time limit to when / how images uploaded to the internal server are governed?
              My uploads from around December last year are gone? Is badcaps forum going under?
              06-18-2025, 05:00 PM
            • bjs59
              Infamous Rubycon MFZ... Current recommended replacements???
              by bjs59
              What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
              12-10-2020, 10:47 AM
            • amijim
              Lelon RXW MSI 694d repair !
              by amijim
              Hello Badcapers ,I am Amijim and I am about to change the caps on two ancient socket 370 dual motherboards from 2001 and I would like to you if the Lelon RXW low ESR caps I can find locally is a good replacement part.Also i would like to ask you what wuld be better ,change the original 2700μf caps to 3300μf or 2200μf? Thank you....
              04-02-2022, 12:09 AM
            • DXseekerMO
              Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
              by DXseekerMO
              Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
              If anyone has a link to where I can buy what I need that would be even better.
              These are the caps that have burst:
              Board location: C8BV, C26BV, C43BV
              Brand: United Chemi Con
              Series: KZG
              Size: 10mm dia X 25mm height
              Impedance: (ohms max/20c, 100kHz) .012
              Ripple: 2800...
              02-04-2022, 04:48 PM
            • xnRS
              Lelon quality
              by xnRS
              How good are lelon caps ? I see some people install RGA Lelons currently. Also could see some old posts where lelons are reffered as the badcaps.
              11-27-2021, 02:45 PM
