Internal images saved here have disappeared
  • randmusr
    • Oct 2024
    • 21
    Is there a time limit to when / how images uploaded to the internal server are governed?
    My uploads from around December last year are gone? Is badcaps forum going under?
  • randmusr
    • Oct 2024
    • 21
    Looking at other new threads here they are gone too.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8324
      Yeah... noticed that too on older threads the pics disappeared.
      • m1ch43lzm
        • Mar 2019
        • 738
        • Peru
        Forum issue, check here https://www.badcaps.net/forum/genera...e2#post3662095
        It affects some users, currently there's an issue with the attachments, even attachments from yesterday don't work while the attachments from some users which didn't work yesterday work now, the admin said he's working on it
        https://www.badcaps.net/forum/welcom...utages-changes
          • 31183
          this has happened before,
          it's caused by upgrades changing the path to the images probably.
            • 115472
            We had a server attack that meant recovery from backup. Unfortunately, it meant also having to very quickly update the forum software from 5.7.5 to 6.1.2 which has been a nightmare. Getting sorted files are still being restored. There may still be issues with some uploads once complete but will see when it finishes
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8324
              I was wondering about a possible server attack, as it had slowed down a lot
              • joshAU
                How to trick notebook into thinking internal panel is connected?
                by joshAU
                Hi all.
                I have an asus F505DV that has a smashed screen, broken hinges, bezel and top cover.
                The customer cannot afford to repair it, so they wanted me to remove the top of the unit and will just use the base as a desktop and plug into a monitor via HDMI.
                However, for some reason, with this model, it REFUSES to display on the external monitor unless there is also an internal LCD.
                If there is a internal screen, then the external displays fine.
                This is running the latest BIOS.
                I have set the display properties in windows 10 using...
                10-06-2022, 11:04 PM
              • lanovey
                SF314-41 BIOS without internal display
                by lanovey
                Hello there,
                I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                06-13-2025, 02:38 AM
              • Rangry
                Razer Blade 15 2022, No internal display, Error Code 43
                by Rangry
                Hi! I have a Razer Blade 15 2022, with a RTX 3060.
                One day, while using Linux, the internal display suddenly stopped working.
                On Windows, it says that the internal GPU has stopped working (with error code 43).
                I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
                I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
                05-29-2025, 07:01 AM
              • grimacelord
                HP 14-dq0055dx - No Power After Shutdown - Must Reseat Internal Battery First, Then Powers On Normally.
                by grimacelord
                Hello again,
                I am once again working on this same laptop that I was working on in this thread. I was able to fix all of the problems that it had, but now it has one final problem. The computer will turn on and work completely fine until you shut it down. Once the computer has been shut down, it will not turn on again, nor will it show charging LED until the internal battery is disconnected and then reconnected. Once the battery has been disconnected and reconnected, the computer will then power on and charge normally and everything is fine again until the next shut down where you...
                05-22-2024, 02:32 PM
              • modtool
                Macbook Pro 14 2021 - A2442 - 820-02098-A - Internal display not turning on but MacOS working good
                by modtool
                Dear collegues,
                the owner of this machine brought it to me saying that suddenly one day the display didn't turn on anymore, he tought that all the machine was damaged but it turned out that the MacOS starts good and stays on, and that connecting it to an external display it works without problems.
                If you take a look into general settings, you can also see that the internal retina display is recognized as connected by the main board but for an unknown reason it doesn't turn it on.
                I've tried to put a bright light towards the screen but I can't see anything, any shadows or apple...
                05-08-2024, 05:50 AM
