Dell dimension 2400
  • mattbrad2
    • Jan 2011
    • 122
    Dell dimension 2400
    Good Lord I get these in the shop more and more lately. Anyone have a clue what makes the motherboard so susceptible to failing? Caps are fine, power supply is fine. For years I've had the same problems with these right after a storm. Seems the board kicks the bucket too easily under a surge.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • SwedishDiesel
    Dell Dimension PSU Compatibility - B110 PSU in 4550
    by SwedishDiesel
    Howdy folks,
    I've risen from the grave to ask more questions about old obsolete Dells.
    I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
    The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
    12-18-2022, 06:58 PM
    Dell Dimension 8200 Schematic
    LA-1221...
    10-04-2024, 07:48 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
