Gigabyte GA-7zx
  • starfury1
    • May 2006
    • 1256
    Re: Gigabyte GA-7zx
    you need to check that they are part of the VRM output circuit
    (with a MM )
    I am not exactly sure why the MB's were designed that way...maybe so they had the option to go either way or possibly more crap type caps in parallel was cheaper then buying high grade caps... at the time
    but it can help you fix something if you got the option open to you
    BTW use only the same type in VRM do not mix and match with that circuit
    replace all if 1 or 2 are stuffed
    The other thing is that VRM output caps should be low, very low ESR....type with good ripple specs
    even GP in those positions may get it to fire but it wont last long cause those caps wont take the punishment that circuit delivers.
    The Input Vrm caps can (and often are) a grade or 2 down but they still need to have good ripple and low ESR specs
    Ideally replace I/P and O/P of VRM for best long term results
    Anyway thats it as I understand it, may have a point wrong here or there
    so people, please correct me if you think I have
    yes reset CMOS and set to safe mode conditions for evaluation is best for a little while
    stating the obvious here but just in case your not aware...of some points
    Anyway sounds like you got some work ahead of you Goodluck
    Cheers
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • Bookworm
      • Nov 2007
      • 123
      Re: Gigabyte GA-7zx
      The entire board is nothing but ZL series now. Boots fine.
      The processor is very tiny, so the abuse on the board should be minimal. It'll be a donation machine, another 'a year is probably good enough'.
      Caps by the memory warm slightly, but still under 34C.
      • Bookworm
        • Nov 2007
        • 123
        Re: Gigabyte GA-7zx
        Oh - As for ripple, I have no doubts that the 1200uF ZL caps I put in there were better than the Choyo and GSC caps of the same (or lower) capacitance.
        • bgavin
          • Jan 2007
          • 1355
          Re: Gigabyte GA-7zx
          Originally posted by Bookworm
          I now have several thousand caps I got off of E-Bay, with another 5-8000 coming along shortly, so I guess I could replace everything with Rubycon ZL or JXA.
          Do you have a source for ZL other than eBay?
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: Gigabyte GA-7zx
            i would have used the 1800 mcz
            • Bookworm
              • Nov 2007
              • 123
              #26
              Re: Gigabyte GA-7zx
              Bgavin - only sort of. I spent some time going over them with a magnifying lens against ones I'd bought in the past, as well as going back and forth with TopCat, before I put any of them in.
              They're Rubycon.
              Kc8adu - they worked. I'm not going to complain. If that machine explodes, they still have spares. I gave them four complete PC's (monitor, keyboard, mouse, computer), and two extra computers. That's one of the 'extras'.
              The _only_ reason I did it is that I had to have it in a machine this morning. I have the right values of caps coming in the mail by Tuesday - but I don't own a time machine.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                Re: Gigabyte GA-7zx
                great it worked out for you.
                btw the zl is likely a much better part than what came out.
                i try to stay as close as possible.the mcz would be the closest of your lot.
                like it matters much.the zl will likely still be good when that board is rotting in the landfill.
                • DynaxSC
                  GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                  by DynaxSC
                  I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                  General test conditions:
                  - Tested with Core i5 6500 and Core I7 6700K - no difference
                  - Default BIOS settings, but tried also altering several memory setting - does not change anything
                  What is wrong:
                  With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                  When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                  03-21-2025, 06:23 PM
                  Thermal pad thickness for various laptop GPU / Graphics Cards
                  ASUS Dual RTX 2070 OC 8GB
                  ASUS ROG STRIX RTX 3080 OC
                  ASUS ROG STRIX RTX 3090
                  ASUS TUF Gaming RTX 3080 OC Edition
                  ASUS TUF GTX 1660 S-O6G GAMING
                  EVGA RTX 3060 Ti XC GAMING 8GB
                  EVGA RTX 3060 XC GAMING 12GB GDDR6
                  EVGA RTX 3080 FTW3 ULTRA GAMING
                  EVGA RTX 3080 TI FTW3 ULTRA GAMING
                  EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                  Gainward RTX 2080 Phoenix GS Specs
                  Gainward RTX 3070 Phoenix 8GB
                  Gainward RTX 3080 Ti Phoenix
                  GIGABYTE AORUS RTX 3080 MASTER 10G
                  02-09-2024, 08:08 AM
                  A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                  by momaka
                  More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                  And a shot of the label:...
                  01-26-2022, 03:26 AM
                  Gigabyte 7X Notebook Specification for Upgrade or Repair
                  This specification for the Gigabyte 7X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7X boardview and 7X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte 7X Notebook is accurate,...
                  09-07-2024, 07:19 AM
                  Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
                  This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
