Had 8 bad caps, 4 Choyo 1200uf 6.3v, 4 GSC 1000uf 10v. This was an emergency recap in the webserver at work. All I had were 1000uf 10v. Is that enough to substitute for the 1200uf 6.3v?
Gigabyte GA-7zx
Re: Gigabyte GA-7zx
Recap was no good. Looks like the MOSFETs got pretty toasty... the backside of the board is discolored where they're mounted. Luckily, we found another identical board that we can put in the webserver to get it back up and running....Ludicrous gibs!
Re: Gigabyte GA-7zx
Well, this board has a bunch of caps, and I don't actually have the right values for them. I think it's just going to get scrapped. The MOSFET's don't appear to be bad, visually, but it does look like they got quite hot, due to the discoloration of the opposite side of the board. I'm guessing it's just dead. Not worth my time to futz around with it any more, since we found the identical board to put in the server.Ludicrous gibs!
Re: Gigabyte GA-7zx
Oh, right.... sorry. As you can see, that's what I did on this 7ZXE- https://www.badcaps.net/forum/showthread.php?t=1267
That's what I had those caps for in the first place.... anticipating more failures in that lab
Ludicrous gibs!
Re: Gigabyte GA-7zx
To necro this thread, I have a GA-7ZX that just came back from a customer - it was on-loan as a basic server.
Upon checking carefully, none of the capacitors were bulged. However, several of the 25v 330uF G-Luxons were obviously tilted off of their leads. To the point where you could look at the thicker part of the internal leads completely. One was almost sideways.
I'll be recapping the board with 10v 1000uF's, and will probably be ordering a few bags of 6.3v 3300's.Comment
Re: Gigabyte GA-7zx
that might have been one of your early gunnie pigs
One of them was the reason I ended up here
Bookworm
yep they are junk get rid of them...BTW whats in the VRM?????
Choyo and GSC be gone too.....on those MB'sYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
Re: Gigabyte GA-7zx
I'm not planning on tossing the board. Even WITH those munged caps, it ran 24/7 for at least two years with no crashes. (It was a loaner server to a customer)
There are only two types of caps on the whole board bigger than a 6.3mm - 330uF/25v, and 1200uF/6.3v
GSC and G-Luxons. (GSC for the 1200uf's)
I now have several thousand caps I got off of E-Bay, with another 5-8000 coming along shortly, so I guess I could replace everything with Rubycon ZL or JXA.
Is it certain that the 330uF/25v are on the 5 volt rail? (and not the 12).Comment
Re: Gigabyte GA-7zx
Bookie, you can get 50 or 200 pc bags of Rubycons from Wai Fong in Hong Kong. I have found them quite reliable and very fast shipping.Originally posted by BookwormI'll be recapping the board with 10v 1000uF's, and will probably be ordering a few bags of 6.3v 3300's.
www.pcbulb.com
They don't have all the Rubycons I need, but they stock most of the common ones. They are the only Rubycon supplier I have found so far.Comment
Re: Gigabyte GA-7zx
I'm going to keep that link, but I have another 12,000 capacitors showing up soon. I'll be set in the expensive end of board caps
(2200uf, 3300uf, and so forth)
Hmm - their link is down right now, apparently.
I guess I should put power to the board and find out how much voltage is across one of those "25 volt" caps.Comment
Re: Gigabyte GA-7zx
I tried their link when I posted this morning, and it was done then. Weekend, perhaps server maintenance...
I have placed three large orders with Wai Fong, and never been disappointed. I would like to find another Rubycon vendor (anywhere) for those pieces that I can't get from Wai Fong.
Another place to search is with Big Pope for SamXon. I understand his distribution agreement now lets him sell large orders to US customers.Comment
Re: Gigabyte GA-7zx
the ZL series you may possibly get away with on the VRM
but I don't think it would be recommended,
better to use MCZ (or older MBZ) series
especially if you going to run it like that 24/7.
(leave that for others to comment on, they would know better then I thought)
I cant give you a yes or no on the 5Volt thing...probably I think from memory
but there maybe a method in the madness with the use of 25 Volt caps lest with respect to USB from what pcbonez has posted.
There is another option too (7ZXE)
There are extra empty positions for the VRM output caps...this does enable you to use
apox 1/2 the uf value and populate all positions
(some say just fill them up, but thats another story)
the other 330uf you could use a lesser series no worries
(ZL I suppose might even be a little over kill).
seems from the post above using 1000uf is no worries too
( Height and diameter can at times pose problems)
Still when alls said and done not a bad run I suppose for what are considered crap caps (24/7 2 years)
Just looking at doods other post, its funny mine had GSC in The VRM output positions
and mine had all popped and yet the 2 that are popped on his, mine were fine.
His VRM o/p caps were Choyo...
I replaced with Panasonic FM's
(3300uf 6V3...diameter was 12.5mm, so they don't sit too well but it works fine)
So yeah go for it don't turf it
anyway just some input on it
Cheers
Re: Gigabyte GA-7zx
I just replaced every capacitor on the board that was 330uF and up. It boots fine (once I remembered to reset the CMOS)
Out of one of the boxes of caps, I ended up pulling out, let's see... 24 10v 1200uF (Rubycon ZL's) caps, and a batch of 1200uF 6.3v KZG's (I had them from a recent purchase, so I'm not too worried).
Man, I have two boxes of 500 caps, and at this rate, I'll run out next week. (Fat chance. I doubt I'll need more than 200 more to finish all the boards I need to do, and I have way too many more coming in the mail this week. I only have about 12 boards to do)
This isn't going to be a heavy duty machine. It currently has an Athlon 1000 in it, and will probably be a 'donation' machine.
Same with the 810LMR I just recapped with underpowered caps
If it lasts another year, I'll consider it worth the effort.
It's just a straight 7ZX - I have another one lined up to be recapped as well.
Oddly enough, the Revision 5.1 board has two less caps than the revision 5.0 board. I wonder if I should go ahead and populate those when I recap it. (Three empty on the 5.0, five empty on the 5.1 )Comment
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
by momakaMore eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
And a shot of the label:... -
Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
Gigabyte A5 X1
From motherboard:
S/N: 1TNH55ER1350895
P/N: 6-77-NH55ERQY-D02-2CGB
On sticker from the back of the laptop:
S/N: SN21351J000657...-
Channel: BIOS Requests ONLY!
This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...09-07-2024, 07:19 AM
- Loading...
