Gigabyte GA-7ZXE REV: 1.1
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    We have a lab of 25 computers with these motherboards in them. This one marks the third that has died. Machine will work, but locks up all the time. Sometimes you get a colorful video output (though they don't have onboard video...), other times it just goes to sleep and won't wake up 'til you restart it. Two visibly bad caps, one GSC 1200uf 6.3v, one Choyo 330uf 25v, both short caps. There are also five total Choyo 3300uf 6.3v "tall" caps around the CPU, which have not visibly failed, and seven Choyo 330uf 25v caps (same as the one failed one) scattered around the mobo that have not visibly failed.
    Do you think it's necessary to replace the other seven 330uf caps?
    (Two offending caps in the foreground)
    Ludicrous gibs!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Gigabyte GA-7ZXE REV: 1.1
    i replaced them on similar board with 1000 16v as per topcat's advice and was totally stable.
    https://www.badcaps.net/forum/showthread.php?t=377
    1000 6.3v is probably fine but check.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Okay... I was going to ask that too... if it was okay to go with a higher uf rating on those... 16v should be okay for a 25v cap?
      Ludicrous gibs!
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Got the following response from Topcat when I went to order the caps:
        "1000uF 16v in place of the 330uF 25v caps is GROSS overkill. Use 1000uF 6.3v or 10v."
        Ludicrous gibs!
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Well, this marks my second successful recap! Got the caps yesterday, and the board is up and running with Rubycons. I did the 5 big 3300uf caps, and the two smaller bulged caps, but left the rest of the uneffected 330uf in place, even though they're from Choyo. I just didn't feel like doing the entire recap. I'm fairly certain that these boards only have to last until this summer and then they're being replaced, but I'm not sure.
          In the future, I probably won't even replace the 3300uf unless they're bulged... these 5 weren't, but I thought I'd replace them because they were from a bad manufacturer.
          Ludicrous gibs!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i would do the whole job the first time.i hate comebacks.
            and those choyo's will likely make it come back like a boomerang.
            remember those pulls will likely still be usefull in a few months for workstations or kids boxes.
            i love free hardware.i get lots of pulls like that.and it all finds new homes fast and its easy money.
            • TerrorBite
              • Apr 2009
              • 3
              I have the 2.1 revision of this board, in a machine that I run as a server. Last night the system became unstable, causing chaos throughout the system and some hard drive corruption as well. I'd previously noticed some capacitors with bulging tops and had been a bit worried about how much longer the board would last, but seeing as everything seemed to be working fine I hadn't given it any more thought. After the crash though, the capacitors were the first thing I checked.
              This is what I found:
              [click for larger size]
              The 6.3V 3300uF between the RAM and the CPU, closest to the power connector, is visibly leaking from the top. The one beside it also shows signs of beginning to leak. The two 3300s near the CPU fan connector are leaning over, and in fact the rubber seal has been visibly pushed out of the bottom of one of them. The fifth 3300 has a bulging top.
              The green 6.3V 1200uF cap that dood pointed out on his board is also bulged. However, none of the 25V 330s show any visible signs of failure (though they're definitely under suspicion).
              All of the caps on this board are Choyo. I'm going to try and source some Sanyo caps to replace at least the 3300s and 1200 with.
              • TerrorBite
                • Apr 2009
                • 3
                Quick question: There's empty spaces on the board for additional caps, is it worth adding extra caps in some of these spaces? Would this prolong the life of the new caps, or would it just be a waste?
                • TerrorBite
                  • Apr 2009
                  • 3
                  Well, I recapped the board and since then was able to run the machine for over 50 days, stable as a rock. Success!
                  <smilies></smilies>
                  • gdement
                    • Jan 2007
                    • 690
                    Didn't see this question until now.
                    Just so you know, those locations (near the CPU) are probably in parallel with the Vcore caps.
                    That was what I found on some other Gigabyte Athlon board, and I've noticed a few of their boards have a similar layout. A multimeter will tell you for sure.
                    On the board I checked, there were 9 cap positions on Vcore, but it was populated with 4x 3300uF caps. So you can substitute 9x 1500uF caps if you like, or try 2200uF if you prefer. More caps in parallel reduces the combined ESR, so you have more flexibility in what series you can install. It should also be more reliable that way.
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      Holy old thread, Batman! I stopped messing with any boards that use SDRAM. Prior to giving up on the older stuff, though, I did recap a fair number of these. Recently, any that were left went to the recyclers...
                      Ludicrous gibs!
                      • DynaxSC
                        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                        by DynaxSC
                        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                        General test conditions:
                        - Tested with Core i5 6500 and Core I7 6700K - no difference
                        - Default BIOS settings, but tried also altering several memory setting - does not change anything
                        What is wrong:
                        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                        03-21-2025, 06:23 PM
                        Thermal pad thickness for various laptop GPU / Graphics Cards
                        ASUS Dual RTX 2070 OC 8GB
                        ASUS ROG STRIX RTX 3080 OC
                        ASUS ROG STRIX RTX 3090
                        ASUS TUF Gaming RTX 3080 OC Edition
                        ASUS TUF GTX 1660 S-O6G GAMING
                        EVGA RTX 3060 Ti XC GAMING 8GB
                        EVGA RTX 3060 XC GAMING 12GB GDDR6
                        EVGA RTX 3080 FTW3 ULTRA GAMING
                        EVGA RTX 3080 TI FTW3 ULTRA GAMING
                        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                        Gainward RTX 2080 Phoenix GS Specs
                        Gainward RTX 3070 Phoenix 8GB
                        Gainward RTX 3080 Ti Phoenix
                        GIGABYTE AORUS RTX 3080 MASTER 10G
                        02-09-2024, 08:08 AM
                        A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                        by momaka
                        More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                        And a shot of the label:...
                        01-26-2022, 03:26 AM
                      • nikovmiroslav
                        Gigabyte A5 X1 Need Bios
                        by nikovmiroslav
                        Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                        Gigabyte A5 X1
                        From motherboard:
                        S/N: 1TNH55ER1350895
                        P/N: 6-77-NH55ERQY-D02-2CGB
                        On sticker from the back of the laptop:
                        S/N: SN21351J000657...
                        08-24-2025, 09:15 AM
                        Gigabyte 7X Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte 7X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7X boardview and 7X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte 7X Notebook is accurate,...
                        09-07-2024, 07:19 AM
