Emachines T3256
  • Mustang
    • Dec 2003
    • 203
    Emachines T3256
    I just received an Emachines system for repair. Model T3256 with an FIC AU31 mobo. The system has spontanious shutdowns, phantom restarts and looks like graphics corruption as well. There's a real mixed bag of caps on this (pos)pc. Smaller caps are ost 1000uf 6.3, and teapo's 220uf. There's also 2 Sanyo 1000uf 16v, 4 Rubycon ZL 820uf 25v and 8 Nichicon HM 2200uf 6.3. A real mixed bag. All caps visually look fine but considering the problems, I wonder if the HM's are causing the problem.
    The PSU is a Bestec 300w (real wimpy unit). Looks like CapXon on primary, secondaries are Jamicon and I think Ost (black with gold stripe can't see it well enough).
    Any thoughts?
    I'll post pics when I get home.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Emachines T3256
    Test the memory... chances are that board has onboard video? If it does, bad memory can cause all of what you listed...
    Ludicrous gibs!
    • Mustang
      • Dec 2003
      • 203
      Re: Emachines T3256
      Thanks for the tip! I'll test it out. I can understand that could be the problem since the onboard graphics does use system memory.
      It's a stick of Samsung 512mb pc3200.
      • Rainbow
        • Aug 2005
        • 1375
        Re: Emachines T3256
        And also try another PSU.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Emachines T3256
          those bestec psu's suck.
          we see them often with blown caps and complete burnups.often takes the mobo with it.
          a celeron 2.6 based one i rebuilt for a neighbor had a 145w in it.i recapped an astec 250 and a msi 478 board to fix it.
          even the restore cd's are worthless after a board swap.
          these things were steaming piles when new.
          • MD Willington
            • Sep 2004
            • 702
            Re: Emachines T3256
            FYI, emachines lookup:
            http://parts.emachines.com/emachines/sys_lookup.asp
            Thats a XP3200+ based system, the 300W PSU in it probably just passes on the minimum specs for a Socket A AMD system...
            I bet if you read the OPN on the processor it will be the 333 version of the 3200+...
            ie runs at 14x166MHz...
            MD
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • Mustang
              • Dec 2003
              • 203
              Re: Emachines T3256
              It looks like it might handle 200w max but definately not a good psu for an Athlon 3200 or any system for that matter.
              • Mustang
                • Dec 2003
                • 203
                Re: Emachines T3256
                MD
                Odd thing is the bios shows the cpu running at 200mhz fsb but the ram is only running at 333mhz! The settings are greyed out so w/o hacking a new bios, maybe only way to get it to 200 is via software. There is a jumper on the board for 100mhz 133/166mhz. I'll set it at 100 and see what happens...
                • Mustang
                  • Dec 2003
                  • 203
                  Re: Emachines T3256
                  OPN is AXDA3200DKV4E XP Barton @ 400. L3 bridges are all closed so a 11x multiplier. Read adding a vid card knocks the ram fsp down to 333 for some reason. Need to fix that issue too.
                  • Mustang
                    • Dec 2003
                    • 203
                    Re: Emachines T3256
                    Swapped out the PSU with my Seasonic 380w, saw the fans twitch when resetting the bios jumper ( a good sign ) then ran memtest for 15 mins. No errors so it looks to be the PSU is the main bugger.
                    • MD Willington
                      • Sep 2004
                      • 702
                      Re: Emachines T3256
                      Nice, usually they throw in those oddball oem 333 bus 3200+'s...
                      The FIC au31 regular bios will probably work...
                      MD
                      • Mustang
                        • Dec 2003
                        • 203
                        Re: Emachines T3256
                        The factory bios is "idiot proof" but that didn't deter the quest for a "real" bios . www.emachineupgraders.info has a good "hacked" bios that opens up the normal settings we're used to. PSU was recapped till my coworker has enough cash to buy a new one. Board runs ok but the southbridge and the addon ATI 9600 vid card are running hot.
                        • Rainbow
                          • Aug 2005
                          • 1375
                          Re: Emachines T3256
                          nVidia chipsets run very hot
                          • dood
                            Deputy dood
                            • Mar 2004
                            • 2462
                            Re: Emachines T3256
                            Glad to hear it's back up and running...
                            Ludicrous gibs!
                            • Chris1992
                              • Apr 2005
                              • 561
                              Re: Emachines T3256
                              About the emachines bestec PSU: I recently had the pleasure of opening a bestec 250w in a tualeron 1200 eMachines box. It had JP CE-TUR and Jamicon caps and a Jamicon fan. I'll swap it out to see if that cures the problems.
                              The great capacitor showdown!
                              • MD Willington
                                • Sep 2004
                                • 702
                                Re: Emachines T3256
                                Nice link...
                                • Mustang
                                  • Dec 2003
                                  • 203
                                  Re: Emachines T3256
                                  Still messing around with this pc. It can't run the memory at 400mhz FSB stable. The pc just freezes. Maybe this is why the factory bios locks it at 400 for the cpu and 333 for ram. I tries loosening the ram timings but still no go. ATM I've gotten it up to 374 fsb w/o a freeze up. Another oddity is the addon vid card (gigabyte 9600 pro) and 3DMark 03 scores. It benchmarks almost identical scores irrespective of FSB settings. Normally the scores go up as the FSB is increased. With this pc, it's a range from 3611 to 3640..a bit higher higher on 1 test..lower on the next etc.. There's a bottleneck in there somewhere I can't pinpoint.
                                  I've tried to change AGP arpeture size and onboard vid size in the bios w/o any luck. Right now this pc would make a great doorstop or an expensive cup holder
                                  • MD Willington
                                    • Sep 2004
                                    • 702
                                    Re: Emachines T3256
                                    They're not that bad, I'm sure someone would love it for doing school work and surfing the web...
                                    • Mustang
                                      • Dec 2003
                                      • 203
                                      Re: Emachines T3256
                                      I agree, it's fine for that The kids use it for online gaming as well. I guess they'll just have to put up with being meatshields until they get a better pc hehe.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Re: Emachines T3256
                                        Probably because it only has PC2700 DDR SDRAM. Most PC2700 DDR SDRAM modules probably max out in the 180s.
                                        My 512 MB of Kingston PC2700 DDR SDRAM (with Infineon chips) hasn't been able to do 200 mhz stably either. Memtest86 failed at anything higher than 195 mhz. 10 errors when been running for 1 hour and a half at 200 mhz and at least 1 error when at 196 mhz. That was on an Asus A7N8X-E Deluxe motherboard I had briefly in late 2004.
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                          ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
                                          This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                        • grimacelord
                                          OLD eMachines T6520 BIOS Request!
                                          by grimacelord
                                          I know that this is probably a long shot, but I figured if anyone could find this BIOS, it would be you guys.
                                          I am working on an (old) eMachines T6520 desktop PC that might have a corrupt BIOS.
                                          Model:
                                          eMachines T6520
                                          Motherboard markings:
                                          MS-7145B0505068731
                                          RS480M
                                          7145 v2.1 RS480-A21+SB400-A23
                                          Symptoms:
                                          The computer does power on, CPU fan spins, but does not POST. No display.
                                          Troubleshooting steps so far:
                                          Replaced the CMOS battery (which was in need of replacing)
                                          Re-seating...
                                          01-12-2024, 12:43 PM
                                          Acer eMachines EM355-131G25ikk Netbook 350 Specification for Upgrade or Repair
                                          This specification for the Acer eMachines EM355-131G25ikk Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EM355-131G25ikk boardview and EM355-131G25ikk schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                        • cnti
                                          Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                                          by cnti
                                          Hi.
                                          BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                                          This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                                          BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                                          RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                                          burned, measured 10M ohm.
                                          QM801 [real PSU:...
                                          10-19-2023, 05:33 PM
                                        • dmill89
                                          Emachines T3104 "Sleeper"/random parts build.
                                          by dmill89
                                          I decided to see what kind of "sleeper" build I could do on the Emachines T3104 from cheep/free thread with the "random junk" I had laying around (with the exception of a SATA to IDE adaptor I bought to make the original Emachines optical drive to work).
                                          Before:
                                          Specs:
                                          Motherboard: FIC K8M-800M
                                          CPU: AMD Sempron 3100+
                                          RAM: 512MB DDR-400 (2x256MB)
                                          GPU: Integrated VIA Unichrome Pro
                                          PSU: HiPro HP-P3527F3 300W
                                          HDD: None/removed (case sticker indicates it originally had a 100GB IDE HDD)
                                          ODD: Lite-On DVD-ROM/CD-RW...
                                          01-23-2023, 09:06 PM
