Via C3m266
    Via C3m266
    I just purchased one of these:
    http://www.digit-life.com/articles2/...-l-cle266.html
    The seller says it worked fine until the capacitors went and it got flakey.
    I'm going to see if I can make a little project out of this and get it going again.
    Should be fun!
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    Re: Via C3m266
    Good luck - there's probably 20+ caps to replace on that one.
      Re: Via C3m266
      The 1-channel switching voltage regulator incorporates 2 capacitors of 1500 uF and 12 of 1000 uF.
      Shouldn't be that bad, I have plenty of the Panasonics leftover from our friends at Soltek! Plus I get to request "Engineering Samples" every once in a while.
      MD
        Re: Via C3m266
        MD, you are lucky to have friends at Soltek, especially if you get enginnering samples once in a while.
        Good luck with the recapping!
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
          Re: Via C3m266
          Sorry I meant I get engineering samples from suppliers at work. Not Soltek.
          I emailed Soltek for some sample caps a while back and they sent me two packages of caps.
          MD
            Re: Via C3m266
            29 GSC caps total, 6 have not bulged, the rest are bulged or puking.
            All others (less than 1000uF) are GSC as well...
            GSC LE series
            1000uF 6.3V
            105 C
            T20B
            GSC LE series
            1500uF 6.3V
            105 C
            T2NA
              Re: Via C3m266
              I have replaced all bad caps with the Panasonic FJ's that I received from Soltek...
              I metered the two pads for the 1500's near the torroids and they appeared to be in parallel so I tossed in a 3300uF... all others are 1000uF.
              Now I need a Tualatin P3 or celeron and some DDR...
                Re: Via C3m266
                I now have a celeron 500...just need to find some extra DDR...
                  Re: Via C3m266
                  Heh well good luck at it. At least you have it working partially. I am surprised you have not gone up to an A64 yet though.
                  #1 A64 3200, Gigabyte K8NS Ultra 939, 1GB Corsair VS, 256mb X800XL AIW, Tagan 480
                  #2 Dell Latitude D810, PM 740, 128mb X600, 1GB Transcend
                  #3 AXP 2100, Gigabyte 7VAXP Ultra, 1GB mixed, 128mb 9800 pro, Epower Puma II
                  #3 down.
                    Re: Via C3m266
                    I have a Biostar on the way for my 3500+
                    To test the Via board I need to steal some DDR from the home PC...
                    Maybe this weekend.
