sahara boards in bookpc's
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    found the typical iq crap caps bad.
    the lettering reminds me of asus but not sure.
    to put real caps in these you have to lay down the ones under the psu to clear.
    to get the clearance needed the stock caps there were standard miniature types and not low esr!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: sahara boards in bookpc's
    Blowing the dust off thread and just for reference purps.
    Sahara is a FIC board.
    From and through roughly i810(440BX?) to i845(i865?) FIC made maybe a dozen mini-book PC's mostly sold as DIY bare-bones systems.
    Some used proprietary MoBos. Others didn't.
    They didn't market them well so they never became very well known or popular.
    I have a Sahara I never did anything much with. Was missing a proprietary drive cable and mount and it took me 6 months to get the rest of the parts out of them. (Not FIC, the retailer.) - By then I'd lost interest in the project.
    Mann-Made Global Warming.
    - Dr Seuss
    • ugamazing
      by ugamazing
      12-17-2024, 07:05 PM
    • ugamazing
      Apple M1 Boards & Exclamatory Error?
      by ugamazing
      We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
      Has anyone else run into this...
      02-20-2025, 09:24 AM
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
    • hopkok
      Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
      by hopkok
      Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
      3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
      I checked for low resistance on coils, no low resistance.
      Anyone with same issue like me?
      Thanks for any help.
      05-24-2025, 04:21 AM
    • midnightg35x
      Panasonic TC-P65S2 SU or SD Boards Bad?
      by midnightg35x
      I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
      04-22-2019, 05:29 PM
