Asus k8v-x se This has been a good board - but suddenly got BSOD while trying to install service pack. Several attempts to reload OS on SATA drive resulted in same BSOD - after XP appeared to load the start files on drive - reboot, Blue screen. Then I tried an older IDE drive - same result. Tried recovery console, fixmbr, fixboot - same result. Checked both drives on other PC's - OS loads normal. The CD-ROM's seem to work. Checked both drive with Seatools - passed 100%. Figuring the HD controller is bad, not reading the drive - could this be from caps? Will try to take time tonight to pull board and check with ESR - but visually they appear OK.
Asus k8v-x se
Tags: None
Re: Asus k8v-x se
Which caps? Show some pics. Those KZGs will fail and they look completely normal.
Also consider that it's the PSU. -
Re: Asus k8v-x se
I'll get some photos up later, have to work right now. I didn't test the PSU, will do that too. Forgot to add - I did run memtest from bootable CD - memory checked fine.Comment
Re: Asus k8v-x se
Don't "test" the PSU. Open it up and check the caps. Most likely that old 20-pin ATX PSU has had its caps stressed beyond their spec for the past 10 years, more than likely they need to be replaced.
I've opened up some old Young Year ATX PSUs (A very popular mid-end ATX PSU at the time), and I've noticed that while the PCB design is identical, they have different caps from model to model. Some of them junk, and some of them not, but they all need attention. I only plan on repairing those that don't use the difficult to source 10mm capacitors for now.Comment
Re: Asus k8v-x se
Finally got time to work on this problem. Swapped power supplies - didn't get a blue screen this time - but windows didn't recognize that there was a drive. six caps near cpu are rubycon MBZ's - 14 KZG - 5 TMZ, plus couple of little ones. Testing with blue esr meter - a lot of them measured 0 - just a few measured .02/.03 - is this because they are in circuit or were they all that bad? Noted that some started out at .05/.06 then slowly ticked down to 0. Thanks, TRComment
Re: Asus k8v-x se
The CPU caps are in parallel hence they cannot be measured in circuit. Lift'em out and see.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Re: Asus k8v-x se
KZGs should all be replaced. TMZ -- I wish I knew. So little information is available on UCC TMZ, I have so many of them, so I would love to know their specs and if they are a reliable series from UCC.Comment
Re: Asus k8v-x se
download memest86+ and see if your ram might have a few errorsCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
Re: Asus k8v-x se
ugh.. look at the toasty CPU VRM area (front & back of the board) and the toasty FET below the AGP slot..
discolored board and all... ugh.. asus.. >.>
but yeah... check your RAM with memtest86+ (click). if that checks fine, get rid of ALL the KZG's.
i've had an A8V series board from a customer here.. fried a couple fets because the KZG's were dead as a rock (even though most of them looked OK).. they dried up
in hot areas, the sleeve also seems to shrink a bit and get slightly darker.Comment
Re: Asus k8v-x se
Quick update - the cooling fan on the PS I used to test started to get noisy - when I opened it had bloated caps. Opened the original PS - recapped and things seemed to work. But lately system has been going blank - or locking up in windows - can only reboot. Next step is to recap MB. Thought perhaps it could be graphics card or cpu overheat - but seem to be cool (with extra fan) - ran memtest and a graphics mem test, showed no problems. Voltages are 12v=12.35, 5v=5.29, 3.3v runs about 3.26, 1.5v=1.55 - all according to Asusprobe.Comment
by guyandpitHi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error2 Photos
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
