I was wondering if you guys could help me identify these bad caps and tell me what I should replace them with.. :/ I've attached two pictures of each side of the cap to help provide as much info as possible.
Dell XM091 (PowerEdge 840) - Help identify caps
Re: Dell XM091 (PowerEdge 840) - Help identify caps
Depending on the dimensions of the above cap, Badcaps.net sells 2 Rubycon MCZ versions of the 1800uF 6.3V cap just in different sizes. Choose the size that matches your United Chemi-con.
See
https://www.badcaps.net/pages.php?vid=22--- begin sig file ---
--- end sig file --- -
Excellent! I just ordered these:
https://www.badcaps.net/store/produc...products_id=37
The motherboard has 3 of these... one of them was bulging out and oozying out of the top.. the other two looked ok but I figured I'd replace them since they are the same kind of caps.Comment
it's an old thread but at year 7; i've noticed that my poweredge 840 has a bad cap. in fact, on ebay; i notice that the cap failure is always at the same point around the cpu.
i will be swapping in my backup server's motherboard and then recapping them; will post pictures then.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by briztechHi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
1 Photo -
by andrew25i have 4 Dell PowerEdge R740 servers, they all have same problem of no display on monitors. they all power up and running okay but nothing displaying on monitor, am suspecting server attack... i attached 1 bios dump and an update exe from dell website, if anybody can rebuild new bios i will really appreciate..
mobo ID: F6MXH
Service Tag: CSPF903...-
by abajorHi all, I've been trying to find some information about this 2024 DELL XPS 9730 Have found absolutely no board views or schematics anywhere.
The laptop suffered some minor water damage around a power mosfet which I cleaned up and replaced. From what I can tell that p channel power mosfet source receives a 12V rail when a power supply is connected but its not passing voltage through the drain.
When I plug in the USB C charger with battery removed I'm drawing .2A at 20V
With battery connected it stays at 5V
Under a thermal camera I can see that this component... - Loading...
