EVGA = Crap??
  • yyonline
    replied
    Re: EVGA = Crap??
    Originally posted by bigbeark
    Anyone care to suggest suitable replacement caps?
    Badcaps.net doesn't carry anything that can replace the 16V 470uF FZ in 10mm. The options in the US are polymer from digikey or 10mm Nichicon HN from mouser. I'm not sure what stores will ship to Canada.
    Specs for 10x12.5mm FZ:
    ESR: 22 mOhms
    Ripple: 1800 mA
    Badcaps carries suitable replacements for all other values of FZ though. For the 8mm diameter FZ, you can use Rubycon MBZ/Samxon GC or equivalent. For the 10mm FZ, get MCZ/GC.
  • c_hegge
    replied
    Re: EVGA
    He did. They are ALL sacon FZ except the ones on the VRM, which are Lelon polys (probably OCR)
  • mockingbird
    replied
    Re: EVGA = Crap??
    nForce 4 right? nForce 4 is ok and worth fixing, unlike all the later nForces which have defective substrate engineering.
    No why exactly would you BUY a board like this? Sure it has two PCIe x16 slots, but don't you know how old 939 is? Also I believe these boards are DDR, at least the A8N-E board I recapped recently was.
    Besides the Sacon FZ, list the brand and series of the other caps.
  • bigbeark
    started a topic EVGA = Crap??
    EVGA = Crap??
    So i bought an EVGA Socket 939 board, 133-K8-NF41, off ebay. Seller admitted it had one blown cap.
    It arrived yesterday, and EVERY cap on the board is SACON, except for the VRM caps which are 10mm 1500uf 2.5v LELON solids.
    I expect I will replace every one of the caps on the board.
    The SACONS are FZ63 1500 6.3V and FZ57 470uf 16V and one FZB 470uf 16V. These are made to look like solids but are vented. All 10mm,
    There are also 2 of the (SOYO leftover?) shiny 1500uf 10v.
    Also 2 little spring loaded push-button switches marked "power" and "reset" as well as
    a goofy looking 2-digit LED.
    This is a SLI board with two x-16 PCI-E slots.
    Obviously EVGA is not trying for high-quality!
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
    Linear Garage Door Opener Control board took a crap install a new control board back normal
    by sam_sam_sam
    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
    02-08-2025, 06:52 AM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
