I have problem with an 20" Imac G5 i bought recently. It's a model from i quess 2005.
The problem is i think somewhere on the logicboard, since the PSU is 100%. I checked that by simple putting in a good working PSU.
Symptons, in folowing of happening:
- first, it bootet up normally. Chime, screen, all oke and lasting for hours.
- When you shut it down and start up again it sometimes worked well, sometimes it won't start up at all or the screen stayed black (but.. Chime!) The fan obviously blowing fast.
- Now, i can do whatever i want, but it won't boot at all. Only the fan start blowing fast, no chime at all. It simply won't boot and the screen stays black
That''s all... the Imac won't boot at all
and it's not the inverter. Otherwise i'd hear some noise, the chime etc.
I've read about reflowing the GPU, what do you think? Is this the problem?
Does a failing GPU leads to a Imac that won't boot complete?
I checked all the capacitors and they look great. No bulging caps at all and the ESR value is also ok. Most were +- 0.10-0.12 or so when measured onboard with a ESR Micro. When we had a screen, we did see a perfect screen. No lines, no failures like often described.
Nevertheless, somethign isn't good at the logicboard, but i don't have a clue what it can be. It's not the PSU, its not the HDD. I swapped them, no difference
Someone an idea?
Someone an idea?
