a 1707 820-00928 20v 1.8A charging battery boot no screen no chime no fans spin
  • apos
    • Apr 2022
    • 12
    • greece
    Hello , i have an a 1707 that is about to blow my mind.I was about to change battery and when i did it suddenly had chime but no screen .I removed keyboards cable from logic board then i had screen .I plugged it again the cable while MacBook pro was on and since then ,no chime no boot, voltages looks ok 20v 1.8A .EDP meter shows no problem ,Thermal camera shows heat on U7210 and U1100.
    Any ideas will be helpful
    Thxxx
  • survivalbloke
    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
    by survivalbloke
    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
    06-14-2023, 11:45 AM
  • Fam787
    HELP! A1398 Dead,
    by Fam787
    I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
    Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
    12-27-2024, 05:19 PM
  • Herby94
    MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
    by Herby94
    I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
    • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
    • When connected, the fans spin for about 30 seconds before shutting off.
    • No display, no audio, and no signs of life during this time.
    Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
    Yesterday, 08:59 AM
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
