Unknown FX5200 Card with bad caps
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Very bad design here. The caps are "Rifeking" and as you can see, 4 of them are touching the heatsink.
    The card boots, but there are many little colour squares on the screen. Is it due to bad caps?
    Is it going to be fixed after a recap?
    And who is the maker of that card?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Unknown FX5200 Card with bad caps
    good chance a recap will fix it.artifacts are the most common result of bad caps on a gpu.
    as for who made it?
    best guess is hong kong flyapart video card inc.
    yeah i know i stole sombodys quote.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      I replaced the bulging caps but the artifacts remain.. So I should assume that the gpu or the ram is bad?
      • brethin
        • Dec 2008
        • 1907
        Best I can tell that is an older Club 3D (European company) card. And most likely the artifacts will be a memory or GPU issue. You could try underclocking it and see if the artifacts go away.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          what shape are the artifacts? screenshot?
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            They are little squares.
              • 31249
              may be gpu, if you push the ram you usually get a snowstorm.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5072
                • New Zealand
                Is it just me or do the AGP contacts look corroded\extremely dirty?
                Perhaps cleaning them will help.
                I have had ethernet and other cards which wouldn't even detect in BIOS and their contacts were nowhere near as dirty as the ones on this card look.
                -David VanHorn
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  It's because of the digital cam's flash.
