kt7a-raid recap
  • fcornillie
    • Jul 2005
    • 5
    kt7a-raid recap
    A few weeks ago, I bought a second-hand kt7a-raid, with bloated caps. I did this knowingly, as I knew this board is absolutely great, and because I still have some hardware which ran on my now dead and dumped MSI board and which I didn't want to sell. So I thought I'd give it a try. The board didn't run smoothly, so I started searching for replacement caps. Before turning to electronics shops, I sent an email to Abit in the Netherlands (the service centre for my region; I live in Belgium), explaining the situation. To my surprise, they reacted really quickly and without any hassle, asking for an address to ship free caps to. Hurrah with bells on!
    The package arrived just this morning, and contains the caps I asked for, except for a bunch of 8mm 1000uF bastards, which are probably hard to find anyway. Leaving the 8mm issue aside for now, the brand of the caps that I received from Abit is TEAPO, which could be fishy (I remember the really ugly TEAPO caps on my former failed MSI board). However, these TEAPO caps are new, and are probably even good, considering the information on the capacitor plague Wiki:
    "Teapo — Teapo has denied these claims, but evidence suggests their new capacitors are sound. However their older ones appear to suffer from the same problems other brands do."
    http://en.wikipedia.org/wiki/Capacitor_Plague
    Furthermore, TEAPO still have a website, in contrast with §é(è"ç Chhsi.
    Would it be safe to use the TEAPO caps?
    My other question relates to the 8mm caps. My Abit board is parasitized by 1000uF Jackcon caps (in a black and gold shell). However, they look perfectly fine, in comparison with the bunch of bloated 2200 and 1500 uF Jackcons (in a green and gold jacket). Also the 10mm 1500 and 1000 uF Jackcons (gold or white and black) sit nicely and unboated on the board. Should I replace the good caps too? They don't show any signs of leakage or bulging, and Jackcon is also still in business, as I can tell from their website. Either way, I don't have any 8mm caps to replace the good-looking 8mm Jackcons, so I would have to leave these on the board anyway. Has anyone had to replace these black Jackcon caps on their Kt7a(-raid)?
    Many thanks in advance!
  • Rainbow
    • Aug 2005
    • 1371
    Re: kt7a-raid recap
    If you don't have replacement caps, leave the old ones there if they look OK. But be prepared that they will go bad too - so check them from time to time.
    I've seen this on Abit BX133-RAID which I recapped for a friend. Most 1000uF were OK so we left them there - but after some time, all of them (both green and black ones) bulged and had to be replaced.
    • linuxguru
      • Apr 2005
      • 1564
      Re: kt7a-raid recap
      Teapo is OK, but if you're going to take the effort to recap the board, I'd suggest using better caps - Panasonic FC, Rubycon YXG, Nichicon PW(M), etc. are widely available, fairly inexpensive and have long lives.
      Jackcon green/gold were bad, but the later black/gold are supposed to be OK. Definitely replace every green/gold Jackcon - they will go bad, sometimes without bulging.
      • fcornillie
        • Jul 2005
        • 5
        Re: kt7a-raid recap
        I don't want to buy any new ones so I'll see how long the TEAPOs survive. This board is meant to serve in a freevo box, which won't be used that much anyway and which is properly cooled, so I expect them to serve for quite a while.
        Thanks for your reactions!
          by momaka
          03-15-2023, 10:17 PM
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • fl0w
          GeForce 6800GT recap, need help identifying caps and finding replacements
          by fl0w
          I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
          But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
          I need to replace:
          • 2x 2.5V 1500µF => I plan to use this
          • 2x 16V 330µF=> I plan to use this
          • 1x 6.3V 680µF=> I plan to use this
          Am I correct with the cap choices?
          Thanks for...
          10-02-2024, 11:28 AM
