Ideq dbvbe
  • jhereg
    • Oct 2010
    • 5
    Ideq dbvbe
    I'm an IT guy who works w/ computers every day. I don't normally deal w/ component level problems. I've been dealing w/ a lot of these shuttle size systems w/ small cases and blown caps. Generally they either won't POST which is what this one does, or they POST and immediately lock up.
    I've been having a discussion w/ some of my coworkers. I've always worked on the theory w/ caps that if they're bulged or leaking they're bad. Even if they aren't bulged or leaking they may still be bad. Others who know far more about board level electronics insist the caps are just a filter and the system should run fine w/ them bulged/leaking. From what I understand, the caps where these are located help control the voltage to the processor. Is this correct, and what would be the consequences of having these caps in this condition?
    This board won't POST so left to my own devices I'd say this board is bad and needs to be either recapped or replaced. I'm looking for the technical reason to tell a boss as to *WHY* the system won't work in this condition.
    Thanks in advance to anyone who takes the time to look at this and reply.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Ideq dbvbe
    I like your choice of thread title. By the looks of those caps, they aren't just bulged, they are OPEN!
    That means that all the electrolyte has escaped from inside and evaporated, which makes the caps just decorations. They do not filter anything anymore. Read about ESR and its importance in switching power supplies, i don't think anyone here feels like explaining it again. Then you'll understand why and have a good answer for anyone that might ask.
    A working TV? How boring!
    • jhereg
      • Oct 2010
      • 5
      Re: Ideq dbvbe
      They're definitely open. 3 of them have pushed the bungs out the bottom. Some of the others are completely vented on top and you can see inside.
      I've been reading about ESR and what it does w/ switching power supplies, but I've been at a disadvantage since I've got a boss who did electronic work (mostly w/ radios / phones) and I don't know how to explain it to him that these are nailed to the perch dead in a way he'll accept.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: Ideq dbvbe
        Just say they have an increased esr and heavily decreased capacitance due to the vaporization of the internal electrolyte and they must be replaced for the computer motherboard to fuction properly. Thatll do it
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Re: Ideq dbvbe
          Leaving the caps in that condition will leave the PCs in the same non-working condition. The electrolyte is gone, and the caps may also shorted internally. I had 3 of these all with the same problem.
          Ludicrous gibs!
          • jhereg
            • Oct 2010
            • 5
            Re: Ideq dbvbe
            I wish. His theory is they are not necessary to the operation of the mb. I've been told they'll work w/o it, and if it won't POST/run to find another reason why it doesn't.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Re: Ideq dbvbe
              whats with the title?
              btw the capacitors are completely vital! it will cause cpu burn-outs, system instabiltiy, and a shitload f other problems
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Re: Ideq dbvbe
                COMPLETELY incorrect. All you have to do is send him a link to these forums, or recap a non-working one and SHOW him the light.
                Ludicrous gibs!
                  master hoarder
                  • May 2008
                  • 12175
                  Re: Ideq dbvbe
                  There was an old thread on here (with pictures) where this one motherboard's mosfets burned (literally!) due to bad caps. Obviously the board didn't work at all after that and was much harder to repair.
                  I can't seem to find that thread right now, though, but I found a few similar ones...
                  https://www.badcaps.net/forum/showth...ghlight=mosfet
                  (for some reason, the picture in that thread doesn't zoom in, so here's a direct link to it):
                  http://img216.*************/img216/4...pandmosfet.png
                  ... And another motherbaord with a bad mosfet from bad caps (3rd picture down).
                  https://www.badcaps.net/forum/showpo...&postcount=184
                  Note the burned ATX connector as well - common issue when the Fuhjyyu caps in old Antecs
                  went bad.
                  If this is not enough to convince your boss, I don't know what to say. Perhaps dood is right, just give him a link to these forums and let him see for himself.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Ideq dbvbe
                    "Others" would then be best described as A PACK OF MORONS!
                    VERY doubtful they have any actual training in REAL electronics. The subject would be covered EARLY in any real electronics training.
                    Filter caps remove Ripple Voltages [aka Noise, aka Static, aka EMI] from the DC power supplied to various IC chips.
                    The only difference between Ripple Voltage and the other kinds of noise are it's source and it's typical frequency.
                    It's adverse affects on electronics are the same.
                    IC chips include: The CPU, the RAM, the Chipset, the Memory Controller, along with all the smaller concerns like HDD controllers, Sound, LAN, Video, and add-in slots.
                    IC chips can not produce a stable output when their power and reference voltages are jumping all over the place.
                    This 'noise' will be superimposed over the top of any Data Signal output from a chip.
                    [Data Signal meaning 1's and 0's which physically are high and low voltages sent from one chip to another.]
                    The Ripple voltage adds to or subtracts from [depending on instantaneous polarities] the signal pulse.
                    The result is a garbled [corrupted] Data Signals because the superimposed noise results in some 1's becoming 0's and in some 0's becoming 1's.
                    - - Bad caps can affect anything on a mobo including things that get blamed on something else.
                    - They can result in corrupt data on hard drives because the data was garbled on it's way through the HDD controller. [HDD gets blamed.]
                    - Good RAM will give RAM errors, not because the RAM is bad but because the signals can't get to/from it. [RAM gets blamed.]
                    Lots of other examples...
                    The source of this Ripple Voltage is switching transistors that turn on-off rapidly to control voltages.
                    Each time they 'switch' there is a small voltage spike. These spikes are the Ripple Voltages.
                    The typical Ripple frequency is in the range of 50kHz to 200kHz.
                    [MOSFETs are common a type but they are just one type of switching transistor used on motherboards.]
                    These switching power transistors exist in the Power Supply, in the CPU voltage regulator [aka VRM], in the RAM voltage controller, there are several for the Chipset as well as maybe a dozen simpler single IC regulators scattered about the board.
                    ""Is this correct"" -- Kind'a sort'a.
                    Those particular caps have two jobs.
                    Job #1 is to remove [filter out] Ripple created in the VRM [CPU voltage regulator] from the VRM 'output' so the power to the CPU is 'clean' DC.
                    There should be some 16v caps nearby. They are part of the VRM. They filter PSU noise out of the 'input' to the VRM.
                    A VRM is basically paired MOSFETs [or pairs of groups of MOSFETs] arranged such that when one is 'on' Vcore voltage goes up [MOSFET connects Vcore to +12v momentarily], when the other is 'on' Vcore voltage goes down [MOSFET connects Vcore to ground momentarily]. There is a controller chip that turns them off and on. They switch on-off so fast Vcore can be held at some voltage between ground and +12v.
                    This [filtering] job is dependent on the capacitor's ESR.
                    A failed cap has high ESR which prevents filtering and keeps the Ripple Voltage in the power.
                    - If the caps aren't doing this job any signals passing through or coming from the CPU can be corrupted with noise/ripple.
                    - The RAM may not be able to 'talk to' the processor.
                    - The processor may be unable to process it's own signals internally.
                    Job #2 is smoothing the voltage changes during load changes. [Like when CPU goes from 25% to 100% or similar.]
                    This is where the cap's 'battery like' characteristics come into play.
                    This job is dependent on the caps capacitance [uF]
                    A blown cap will have low [or no] uF and it's storage capacity [no pun intended] is reduced or nonexistent.
                    - A good sized load change would be enough to cause the CPU [and system] to crash.
                    - It can also cause boot-looping. - Repeated crash and reboot.
                    - If the caps don't charge at all it can prevent start-up completely.
                    ^^ As long as that is, it's still only the basic idea. Lot more to it.
                    It absolutely needs recapped.
                    Either that or write it off and replace it.
                    Print this and hand it to him.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      Re: Ideq dbvbe
                      looks like the msi boards i have to cap first thing when i get back.all vrm input and output caps blown open.no surprise it wont post.
                      got a bunch of itox boards to do that are blown up the same way.ncc kzg.
                      • jhereg
                        • Oct 2010
                        • 5
                        Re: Ideq dbvbe
                        That's exactly the info I needed. Unfortunately you get nowhere telling a boss they're a moron, so I'll use the info you gave me to support my cause. Like it or not I have to be diplomatic about it. Thank you.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: Ideq dbvbe
                          You should replace all the KZG caps.
                          That particular series has a habit of failing without bloating at all.
                          - Dr Seuss
                          • jhereg
                            • Oct 2010
                            • 5
                            Re: Ideq dbvbe
                            I missed this earlier. The title is the model number which is printed on the back of the case. it's an iDeq computer which is the same form factor as most of the Shuttle PCs.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Re: Ideq dbvbe
                              lol ok it seemed like you just wrote random letters
                              • ziplock
                                Abit BE6-II motherboard
                                by ziplock
                                Greetings,
                                I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                                I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                                04-20-2025, 02:09 PM
                              • captain150
                                by captain150
                                03-16-2025, 07:34 PM
                              • Blag
                                Japanese 3DO with leaking caps - (nearly) full poly replacement
                                by Blag
                                Hi all, I've got a 1994 Japanese Panasonic 3DO with 2 leaking caps. Since all the caps are now 25 years old I decided to swap them all before more of them start to leak.
                                To reduce the danger of another leakage in the future I decided to swap every possible cap with a poly cap.
                                Has anyone here done that already and give me some hints?
                                I found a "fitting" (voltage, uF and measurements) poly cap for all but 3 caps. The largest cap is a 6800 uF 25v cap, since there aren't any 6800er polys I'll get a high quality electrolyte one with a higher temp rating. The...
                                10-26-2019, 07:59 PM
                              • black6host
                                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                by black6host
                                Good day!
                                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                I'm going to replace the caps and I'll be the first...
                                02-06-2024, 08:22 PM
                                EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                                by momaka
                                I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                                So, here is the...
                                06-06-2020, 04:39 PM
