Hp 22-DD0302IN aio strange issues
  • mcplslg123
    • Jun 2015
    • 7263
    • india
    MODEL:HP ALL IN ONE 22-DD0302IN
    Problem:
    hp bios update failed unable to open bios image file
    This message pops up and it reboots in a loop. I've flashed 086F3 bios from HP site and replaced eeprom chip as well.(Replacement is also 1.8V chip). After flashing, still get the same pop up error msg.
    I thought it may be bios image update is stored in SSD(Kingston 250),so i replaced the ssd with samsung 512 nvme.
    The mb doesnt show anything on screen when any other SSD is installed(I tried several brands,capacities) even though its new. Went ahead and removed SSD and inserted win11 bootable only with no hdd/ssd.Still no image on screen.The moment you put its original kingston 250 back,there is display on screen with error popup.
    Whats the way out? I tried my level best but couldnt understand the puzzle.Could it be EC firmware?
    PS: MB posts correctly with other SSD as well(usb kbd numlock light works with no image on screen.)
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • electronics and DJing/producing music
    Re: Hp 22-DD0302IN aio strange issues
    Bootblock likely looking for a recovery image on the SSD. I would try flashing a dump from another machine rather than the update file from the website, it could be incomplete.
    A working TV? How boring!
      • 24678
      Are you the first tech to work on the PC or has the bios been flashed before. If you`re the first you must have looked at the BID and found 086F3 ,you would expect it to be the correct version.If you`re not the first or you suspect microsoft update has somehow flashed the wrong one then there are 5 more bios to choose from.Its the same number of bios options whether you enter the model number 22-DD0302IN (it gives another option to choose product 681U0PA, if that isn`t the product you should search for updates by series instead - https://www.badcaps.net/forum/showthread.php?t=122195) or if you choose by series 22-DD0000i .
      Edit: Forget all that,the other 5 are all intel bios.
      • mcplslg123
        • Jun 2015
        • 7263
        • india
        The hp website has complete 16MB bios,so that cant be the issue.
        Yes I'm the first tech to open up the PC. i've read the bios and its BID is 086F3 for sure.
        What is puzzling me is that there is display on screen only with KINGSTON 250 SSD(which came with this PC) and no display if you put any other SSD.
        I dont think its main bios issue since i've access to another bios read from same PC and flashing that bios also gave same symptoms. thats why i didnt posted it in the bios forum.
        • mcplslg123
          • Jun 2015
          • 7263
          • india
          Finally was able to solve the mystery. Opened the backup read from original bios in hex editor. zerro filled entry from hex D000-DC6F which were all entries showing bios upgrade failed. Saved this bios and re flashed on the PC-still same error boot loop. tried usb recovery this time it worked and flashed bios successfully after several reboots. earlier when usb recovery was tried(the same pen drive was used earlier with exact same contents),it didnt gave any beep sound and nothing went correct but this time it worked. Not very convinced myself, but anyway case solved. It seems in such bios flash failure,usb recovery only works any flashing the bios chip externally perhaps dont work.Thanks everyone who responded
          PS: Now any brand nvme ssd works on this PC.
          • ronelex
            • Oct 2016
            • 215
            • Philippines
            Hellow sir, can you share the bios you use? is it for ryzen processor? I also have this problem https://www.badcaps.net/forum/showthread.php?t=123248
            • ronelex
              • Oct 2016
              • 215
              • Philippines
              Problem solved, reflash bios by the one I got on the BIOS update install on my USB,
                • 24678
                I`m happy you got it fixed,and thanks for the info you gave me via PM.
                • mkdj
                  What should I do after having flashed a BIOS?
                  by mkdj
                  Dear all,
                  I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
                  Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
                  09-09-2025, 09:45 AM
                • cr4zychriss
                  by cr4zychriss
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
                • yellowtiger
                  Lenovo Slim 7i 14IMH9 - Failed BIOS Update and Stuck in Boot Loop - BIOS Request
                  by yellowtiger
                  Hello Everyone,
                  I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
                  Here are my laptop details:
                  - Model: Lenovo Slim 7i 14IMH9
                  - Serial Number: YX09M0K7
                  - Machine type: 83D80003US
                  **Problem:**
                  About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...
                  06-14-2026, 11:04 AM
                • Boardview and Schematic Bot
                  How To Check BIOS / EC firmware version for MSI notebook & Update it
                  Not sure how up to date this is....
                  How To Check BIOS/EC firmware version for MSI notebook?
                  Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
                  1. How to check BIOS/EC version by Help Desk?
                  1.1. Open MSI Help Desk.
                  Note: Help Desk is a built-in application for MSI notebooks. If you couldn’t find this software in your Windows system, please download and install MSI Help Desk from product.
                  1.2. Click the [System Info].
                  1.3. BIOS and EC firmware version will display on screen.
                  03-27-2026, 01:12 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
