820-2784-A no picture/backlight
  • AJ847.63e
    • Aug 2020
    • 168
    • Africa
    Firstly does anyone have the correct bv/schematic for this board? The one I downloaded from here has all the parts mirrored making it really difficult to test things.
    We've got a bunch of old iMacs I'm trying to go through. All bar one were the single long beep so it looks like they need a ram slot reflow.
    The single one that wasn't doing the long single beep it would bong you could see the light on the bottom of a usb mouse come on and the fan also comes on so it seemed like it was booting but I would get no lights on the keyboard, no caps lock. Shining a flashlight couldn't see any picture screen looks completely black so it does look like it's initialised (usually the screen would be grey if it wasn't). If you leave it on for a few minutes than hit the power button again it bongs again so it seems to be failing post and shutting off.
    Took the board out and noticed the first two leds would light up but that's it. Tried power cycling it a few times and now maybe 1/10 times it gives the long 3 ram beep other times it bongs and gives the same original symptoms.
    Should these boards be able to post without the GPU? I know these are a common fault so I've tried both with and without a GPU, haven't tried replacing it though as I'm struggling with space as it is so I haven't been able to tear down another one.
    Doesn't seem to be a RAM fault as it is getting powered. CPUs heating up as expected so it seems all the required rails are indeed present. Haven't been able to dig through the power sequences though since the board view released seems to be mirrored, pp3v42 for instance the two resistors and cap are supposed to be on the right of the regulator according to the bv but on the board their on the left.
    Thanks for the assistance.
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • mrsith
    Sony KDL-65W855C mirrored, fading picture
    by mrsith
    Hi, me again.
    Grabbed that Sony with 6 blinking lights. Easy job, especially that I had LED set. Replaced them, upon reinstalling everything and doing test I was shocked. The picture is upside down and mirrored. There is some fading effect on one side (4th TV in a row with backlight problem that turned out to have this issue as well...), and there are 2 black vertical bars. Touching side and bottom tabs doesn't produce any change at all.
    The LEDs were taken from kdl-x857c, basicay same model. I transferred screen to its chassis to save time, but just in case of any incompatibility...
    08-19-2022, 03:42 AM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • tech_guru
    Dell Inspiron 15-3521, 5 Beep Code - No Picture
    by tech_guru
    Hello.
    I have a problem with this laptop DELL INSPIRON 15-3521 (Motherboard VAW01 LA-9101P REV 1.0).
    At first it came with 1 beep code continuously and no picture. I flashed the bios with programmer and it turned on but now some times, not always, it does not turn on and gives 5 beep code, which Dell states it is Real Time Clock Power Failure. The cmos battery is new. If it boots up correctly, it stays on and works perfectly.
    Do we have any idea what it could be or where to start diagnosing? I have schematics and boardview.
    Thank you.
    07-08-2022, 07:40 AM
