Asus X99-s USB overcurrent detected
  • brusli009
    • Jul 2023
    • 46
    Hello! so i have an Asus X99 S and a X99 Deluxe, both have been working for some time, but after swapping the cooler on the X99 S it started to come up with the USB overcurrent detected. I have tried all the bios versions on the asus site, have looked if anything is shorted and all of the usb ports show almost the same resistance on the pins.
    Tried different ram, cpus, psu, also all the pins are nice, and no usb port is bent.
    Only way to make it boot 1 time only was flashing a new bios on the chip (ch341a or bios flashback) and then getting into the bios, but only the usb 2 ports would work. The usb3 ports only had power going to them but no communication.
    I have looked for schematics but the closest i could find is the x99 deluxe which is almost the same but has more usb ports.
    Any help would be nice
    MOD Edit: Boardview moved to "Bios and Schematics" Requests sub forum -> https://www.badcaps.net/forum/showthread.php?t=121934
    • 31015
    Re: Asus X99-s USB overcurrent detected
    what does it do with the cooler unplugged?
    • brusli009
      • Jul 2023
      • 46
      tried with cooler on and off since and the same stuff, different coolers too
        • 31015
        start looking near the cpu for damaged smd parts then
        • DynaxSC
          • Apr 2021
          • 461
          • Poland
          USB overcurrent schuldn't have anything to do with cooler. I'd guess some smd device was ripped off during swapping of the coolers. Looking for ripped off smd components is a good idea, but I would extend the search for the whole board if you have taken out the board for the cooler exchange. Have you checked if all USB port have the 5V power ?
          • brusli009
            • Jul 2023
            • 46
            I have checked and all usb ports do have 5v, even the case ones
            • brusli009
              • Jul 2023
              • 46
              I have found that the asm1187e gets very hot when powering the board on, on the schematic it is y1u1. I dont really know how to check what it does or if it has anything to do with the usb overcurrent, but my guess is that it shouldnt get this hot.
              • DynaxSC
                • Apr 2021
                • 461
                • Poland
                This will be the issue, there is not much info about this chip, but it is generally a PCI to USB bridge. If it is very hot (over 50 C) then you need to replace it. It most probably leads to a power supply overload, and thats why you get the error. I observed that these AS Media chips are quite sensitive and get often demaged due to electrostatic discharges on the USB ports. To replace this smd device you will need a hotair station preferably with a preheater and some captan tape to protect the plastics on the board from the hot air (use several layers dependent on distance to the plastics). You can buy the chip on Aliexpr..... You schould also check, if any of the USB data lines behind the AS Media chip do not have shorts. All USB ports are protected by such very small 6 pin spike protector devices located very close to the ports, they should protect the USB controllers behind but not always this works. So it might be that beside the AS Media chip also one/some of these spike protectors are shorted. Best is to check them after taking the AS Media chip from the board, because the AS Media chip may also have a short on the data lines.
                • brusli009
                  • Jul 2023
                  • 46
                  I quickly checked on a working x99 deluxe and it also gets hot, cant tell the reading cuz no thermal camera and also covered by the gpu. As for replacing it i got a gordak 952 hot air station and was planning on buying a preheater also, i may try to replace it in the future, tho it may not be the problem
                  Also from looking more at the schematic only the wifi card slot and the lan are connected to this chip and the rest of the usbs are connected to 2 other asmedia controllers but those arent getting hot at all
                  • DynaxSC
                    • Apr 2021
                    • 461
                    • Poland
                    Yeah, these chips get quite hot, but the question is how much, till ca 50 C it is still somewhat normal, 60 C and above is most probably damaged. Try to measure the temperature, and check the USB data lines. Usually if your finger tip gets burned, then it means chip is dead, but this is not an exact method. A cheap laser distance thermometer or the temperature probe of a multimeter with some liquid should do the job. You can also measure the resistance of the VCC supply of the chip in power off state, if it's somewhere in low ohms range (10 ohms and lower), this is also an indicator, that the chip is dead. Compare also to the working board.
                    • brusli009
                      • Jul 2023
                      • 46
                      Forgot abt the multimeter probe, with it dosent go above 41C and the chipset with no heatsink is around 42C also. Also the suply in the power off state is @50 ohms, and tested the same on the working board
                        • 31015
                        logically, check the wifi card slot (caps related to it) and the lan for shorts
                        • brusli009
                          • Jul 2023
                          • 46
                          Did that and nothing looks abnormal, every ground is where it should be and the other pins have resistances on the wifi slot. on the lan port everything is good and resistances are the same on all pins of data
                          • brusli009
                            • Jul 2023
                            • 46
                            Ive heard asus stores some data on the bios file and if you flash it via a programmer that data is deleted, i have flashed it via a programmer so maybe thats the problem? if so is there somebody that can share a x99-S bios dump?
                              • 20873
                              Bios and Schematics Requests sub forum -> https://www.badcaps.net/forum/forumdisplay.php?f=15
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3593
                                • slovakia
                                there is small chip near usb ports when gets damaged, it will trip that error
                                  • 31015
                                  you mean the usb power switches?
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3593
                                    • slovakia
                                    on this board check all U_USBOC nets. they r connected to chipset so it can be even bad solder joint
                                    • brusli009
                                      • Jul 2023
                                      • 46
                                      After being gone for a week ive come back and the board is stuck at 00 and shortly stops after. Checked 12v and its still getting it and all the other mosfets for the cpu are getting the voltage needed
                                      • cloppy007
                                        • Jun 2022
                                        • 6
                                        • Spain
                                        00 usually means a big issue with your cpu. What BIOS version are you running?
                                        Have you tried reseating your CPU?
                                        • ronelex
                                          ASUS TUF B450M-PLUS-PRO GAMING USB Overcurrent Detected
                                          by ronelex
                                          Hello, so I got this ASUS TUF B450M-PLUS-PRO GAMING come in the shop with an issue of USB Overcurrent Issue. I already disconnect the USB connector going to the front USB port, and Check all port in the back and all are working and no short is detected,. Maybe someone can guide me how this USB Overcurrent Works because I got to boards with the same issue
                                          01-30-2024, 09:35 AM
                                          ASUS ZenBook UX490UA-77DHDAB1 Notebook 3 Deluxe Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX490UA-77DHDAB1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-77DHDAB1 boardview and UX490UA-77DHDAB1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:37 AM
                                          ASUS ZenBook UX490UA Notebook 3 Deluxe Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX490UA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA boardview and UX490UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ZenBook...
                                          09-06-2024, 08:29 AM
                                          ASUS ZenBook UX490UA-IH74-BL Notebook 3 Deluxe Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX490UA-IH74-BL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-IH74-BL boardview and UX490UA-IH74-BL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 06:48 AM
