FIT/CSME Tool (Flash Image Tool) - Trusted Download Location?
  • pdblues2231
    • Jun 2022
    • 53
    hi,
    try this.
    • aki_daglog
      • Aug 2024
      • indonesian
      #42
      Originally posted by pdblues2231
      hi,
      try this.
      ok thanks.
      • nafienew
        • Aug 2014
        • 115
        • up
        #43
        PLEAS NEED
        Intel Me Region 12.0.47.1524
          • 22021
          Originally posted by nafienew
          PLEAS NEED
          https://mega.nz/folder/PJFXnCDK#lWSX5W0ODubZ2pf3gu3unw
          • nafienew
            • Aug 2014
            • 115
            • up
            #45
            Thank you very much for the wonderful file. I just want to ask about the matching program that works with this file. I tried this version Flash Image Tool 12.0.68.1606 and it did not work for me
              • 22021
              Open your bios with MEAnalyzer and check which FIT version was used. There are 7 different FIT 12 versions that i know of ,you can find them all on the internet. If you can find the same FIT version the bios should open with it, but if not try an older version.
              • Godfather79
                • Nov 2025
                • 3
                • Serbia
                #47
                Hello everyone and a big greeting.
                CSME System Tool v15.0 r15 Can help for Dell Latitude 5520 3FE2 Bios Password locked
                Thank you
                  • 22021
                  Thank you
                  Cleaning the ME firmware will not remove the bios password.
                  • Godfather79
                    • Nov 2025
                    • 3
                    • Serbia
                    #49
                    Greetings to you and the entire forum community.
                    Thanks for the quick reply
                    How can I remove Bios password and create Bin.file myself to unlock Dell Latitude 11th 5520 3FE2?
                    Can I get a tool so I can learn how to remove the Bios password myself in the future?
                    Thank you
                    • wenl619
                      Intel (R) Modular Flash Image Tool. Version: 18.0.10.2285
                      by wenl619
                      Intel (R) Modular Flash Image Tool. Version: 18.0.10.2285...
                      02-22-2025, 12:27 AM
                    • apppostol
                      Looking for flash image tool v16.1
                      by apppostol
                      Hi all. The program version 16.xxx is very necessary.
                      Can't find it anywhere. Is it really that rare? Maybe someone has. I will be very very grateful.
                      02-28-2023, 12:12 PM
                    • ferah831208
                      help with bios decompose for Asus s5506ma
                      by ferah831208
                      I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                      08-24-2025, 05:35 PM
                    • tsavpyn
                      Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                      by tsavpyn
                      Dear all,
                      I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                      Now I have a problem that I am unable to dump my BIOS into bin file.
                      My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                      I searched for FPT but there is no Linux version and none of them work.
                      I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                      I would really appreciate it if anyone...
                      05-28-2024, 11:18 PM
                    • ekozeko333
                      [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                      by ekozeko333
                      I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                      🔥 The Problem Started After Suspected ESD/PD Fault
                      I experienced a power issue or ESD event through a USB-C charger
                      After that, the NX20P5090 power switch was visibly burned and was replaced
                      Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                      🧠 What I’ve Done So Far
                      Flashed...
                      06-21-2025, 02:48 AM
