FIT/CSME Tool (Flash Image Tool) - Trusted Download Location?
  • pdblues2231
    • Jun 2022
    • 43
    hi,
    try this.
    • aki_daglog
      • Aug 2024
      • indonesian
      #42
      Originally posted by pdblues2231
      hi,
      try this.
      ok thanks.
      • nafienew
        • Aug 2014
        • 103
        • up
        #43
        PLEAS NEED
        Intel Me Region 12.0.47.1524
          • 21590
          Originally posted by nafienew
          PLEAS NEED
          https://mega.nz/folder/PJFXnCDK#lWSX5W0ODubZ2pf3gu3unw
          • nafienew
            • Aug 2014
            • 103
            • up
            #45
            Thank you very much for the wonderful file. I just want to ask about the matching program that works with this file. I tried this version Flash Image Tool 12.0.68.1606 and it did not work for me
              • 21590
              Open your bios with MEAnalyzer and check which FIT version was used. There are 7 different FIT 12 versions that i know of ,you can find them all on the internet. If you can find the same FIT version the bios should open with it, but if not try an older version.
              • wenl619
                Intel (R) Modular Flash Image Tool. Version: 18.0.10.2285
                by wenl619
                Intel (R) Modular Flash Image Tool. Version: 18.0.10.2285...
                02-22-2025, 12:27 AM
              • apppostol
                Looking for flash image tool v16.1
                by apppostol
                Hi all. The program version 16.xxx is very necessary.
                Can't find it anywhere. Is it really that rare? Maybe someone has. I will be very very grateful.
                02-28-2023, 12:12 PM
              • ferah831208
                help with bios decompose for Asus s5506ma
                by ferah831208
                I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                08-24-2025, 05:35 PM
              • tsavpyn
                Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                by tsavpyn
                Dear all,
                I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                Now I have a problem that I am unable to dump my BIOS into bin file.
                My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                I searched for FPT but there is no Linux version and none of them work.
                I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                I would really appreciate it if anyone...
                05-28-2024, 11:18 PM
              • ekozeko333
                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                by ekozeko333
                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                🔥 The Problem Started After Suspected ESD/PD Fault
                I experienced a power issue or ESD event through a USB-C charger
                After that, the NX20P5090 power switch was visibly burned and was replaced
                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
