Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting everytime like 12v, 5v and 3.3v ) and vcore voltage is producing up tu 1.1v then goes to 0v and this keeps like that during power cycle, also the cpu power (red led light is not coming up) isn't working, but if you try to power it on without 12v eatx cpu power cable, system is getting power and doesn't enter the power cycle and all voltages are stays OK (12v,5v and 3.3v) but if you attach 12v cpu power it's entering the power cycle, also all cpu pins are OK, no bend, cpu is also OK, and there is no short circuit on 12v cpu power line.
However if I force to power on motherboard with all power cables attached (atx 24 pin + eatx 12v cpu) by sorting green and black cable on psu, it doesn't enter the power cycle loops but cpu vcore voltages is not producing also system doesn't boot again (no display) but nothing is also not getting even warm (i mean no symptoms of short circuit)
So guys help me , what to do ?? And what might be the problem?? Can it be an damaged bios firmware?? Or some other issue??
Ps. I have bordview diagram for this board and inspected the 12v cpu power phase line but everything seems to normal, I am unable to find the problem
Can it be an currapted bios or bad pch chip?
