RTX 3070Ti works normal, but when let 10min to work on full it crash
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Hello.
    I have few RTX 3070Ti that works for hours on 90% of TDP, but when pushed to 100% tdp it crash in 10-15minutes. Cards was repasted and repaded, but still the same. Do u think that reball wil help?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: RTX 3070Ti works normal, but when let 10min to work on full it crash
    Yep could be ram or cpu needs reball, I’ve done 2 with driver/load crashes etc.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3582
      • slovakia
      Originally posted by ReeceyBurger123
      Yep could be ram or cpu needs reball, I've done 2 with driver/load crashes etc.
      driver load crash is easy fix. i done MANY. but this is WAY different
      • Burnedoutplacebo
        • Jan 2023
        • 19
        could it be one phase of VRM not working?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3582
          • slovakia
          nope.all phases work
          i flashed bios with lower TDP and now card work on full without problem
          • simwalsh
            Philips 47PFL4606 Powers on, works normal then powers off after a minute
            by simwalsh
            I am new to this forum and have searched for some answers with problems similar to mine.
            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
            It sounds like a power supply issue?
            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
            12-04-2023, 04:03 AM
          • Instafixx
            Macbook A2179 820-01958
            by Instafixx
            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
            I checked the Power Sequences below and found this -
            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
            05-20-2023, 05:19 AM
          • CapLeaker
            Dell ATX PSU won’t start, but forcing it works fine?
            by CapLeaker
            Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
            Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
            10-28-2024, 06:59 PM
          • cook
            HP Power Supply 6632A: Fast Mode vs Normal Mode?
            by cook
            FAST MODE vs NORMAL MODE
            I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
            I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
            06-07-2020, 05:32 AM
          • ex250
            Kenwood SW-505D no sound issue and pops from time to time when it works
            by ex250
            Hello mates,
            I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
            It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
            12-29-2024, 03:27 PM
