msi rx580 - GPU got a too high voltage 1,45v
  • conghuyms
    • Apr 2022
    • 50
    • Vietnam
    GPU got a too high voltage (over 1.45V) - msi rx580-8g
    works for 10 seconds ---> dump
    pls help me . thanks very much
  • ductranvinh
    • Dec 2021
    • 135
    • Republic of Vietnam
    Re: msi rx580 - GPU got a too high voltage 1,45v
    coi lại con ic lớn RT. con nguồn nhỏ 0.9 có áp chưa. ko dc nữa thì tháo con apw8713 hay con gs9230-gs9238 ra r câu thẳng 1.1v vào từ máy cấp dòng xem ăn bao nhiêu ampe.
    review the big ic RT. small source 0.9 has no voltage yet. If not, then unplug the apw8713 or the gs9230-gs9238 to get 1.1v straight from the line feeder to see how many amps it takes.
    PC work for schemaltic:
    Mainboard: Gigabyte Z68XP-UD4
    CPU: I3-3240
    Ram: 16Gb
    Graphic Card: GTX 1050Ti zotac 4Gb Mini
    SSD: 120Gb
    HDD: 2Tb
    • conghuyms
      • Apr 2022
      • 50
      • Vietnam
      Hey bro. I'm a newbie without a job,
      Up until now, I went to school but the teacher only taught this line of vga or the error of this ic and that ic and then replaced it without specific instructions. bjo I have a question with the line vga rx 470->rx580 in order to check the source, for example rx580 msi lost all power, vram, vcore ,0.9v , 1.8v.
      I don't know where to start checking because I don't know which source comes first and which comes after. Can you spare a little time please, can you tell me? thank you so much
      • vcaina
        • May 2023
        • 12
        • Philippines
        Hi Mate! I'm also a newbie who is constantly searching for more knowledge. Here's a screenshot of the power rail for that series of GPUs. I got this from the youtube video "The GPU REPAIR GUIDE. How to fix GPU /Graphics card not detected. AMD Radeon or Nvidia", it's a good watch, check that out.
        I know once your turn on, 12v, 3.3v, and 5v should also turn on. Once these rails are online, you'll get 1.8, pex and vmem and vcore so I believe those are the pre-requisistes, please correct me if i'm wrong everyone.
        • conghuyms
          • Apr 2022
          • 50
          • Vietnam
          thank yoy verymuch
          • conghuyms
            MSI RX580 Vcore voltage is too high, please help me !!!
            by conghuyms
            I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
            I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
            Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
            What should I do...
            08-02-2025, 11:38 PM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • SoporteHR
            LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
            by SoporteHR
            Greetings to all, I hope you are well.
            I consult you because I have a problem with this power source.
            The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
            When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
            I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
            but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
            06-20-2023, 04:30 AM
          • harp
            high voltage high resistance marking resistor
            by harp
            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
            08-26-2024, 01:42 PM
          • harp
            Low voltage very high current rails distribution
            by harp
            Low voltage very high current rail distribution
            I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
            Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
            output on half E-F
            output on C-B
            connect A-B and C-D, output on A-F
            otherwise?...
            10-27-2023, 02:45 PM
