Fixing Gigabyte GTX 670 OC 2GB
  • saken
    • Feb 2023
    • 18
    • GER
    i have a Gigabyte GTX 670 OC 2GB here which shows no picture.
    - Fans are spinning
    - Windows detects the card as „Microsoft VGA Adapter“ when inserted as 2nd card
    - MemVoltage = 1.6V
    - Vcore = 990mV
    - 3,3V and 5V ok
    - Pex = 1.054V
    - No short circuit
    - All resistances i could check are ok
    Is there anybody who wants to help me?
    Greetings
    Alex
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Fixing Gigabyte GTX 670 OC 2GB
    mostly memory comunication fault. bad connection under gpu, bad connection under ram chip.
    did windows try to download driver for that second card?
    • saken
      • Feb 2023
      • 18
      • GER
      I'll check that and get back to you.
      • saken
        • Feb 2023
        • 18
        • GER
        I was wrong.
        Windows detects the card as „Microsoft Basic Display Adapter“ when inserted as 2nd card.
        And windows is not trying to download the driver.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          what if u manually install driver?
          • saken
            • Feb 2023
            • 18
            • GER
            Hey,
            now windows is downloading and installing the driver correctly. It just took some time to start.
            So what does it mean?
            • stormanimal83
              • May 2014
              • 74
              as somebody alrerady mentioned your card has problems with either the ram or the connection between gpu and ram. its sometimes normal behavior for card beeing detected as "basic video adapter" and other "standard vga graphics adapter"....
              in most cases you ´ll get a blank screen or blackscreen when windows is loading the correct driver for your card... after deinstalling drivers card works again in "safe mode" as mentioned...
              • galkinvv
                • Apr 2023
                • 4
                • Russia
                If the GTX670 problem is related to the vram or the connection between gpu and vram it can be worked around by disabling broken memory channel. For GTX 670 it would reduce the VRAM amount from 2GB to 1.5GB and the memory bus width from 256bit to 192 bit. But it is quite fast, pure software solution.
                This can be done with "Old NVIDIA artifacts" utility - see downloads and user manual
                Here is example of its usage on GM1017-based quadro - the upper screenshot is the initital state, the lower one is the state after fix.
                P.S. I am the author of the utility mentioned above. It supports only GF1xx, GK1xx, and GM107 chips.
                Later chips starting with GTX950 GM2xx are NOT supported.
                • saken
                  • Feb 2023
                  • 18
                  • GER
                  now i was able to run mats. Here are the results. Seems like the memory chips are ok?
                  • saken
                    • Feb 2023
                    • 18
                    • GER
                    i got some news. When i connect the GTX670 with RiserCable as 2nd card. The card works, see Screenshots below.
                    But when i connect the GTX670 directly to the mainboard, the card is not detected.
                    Any ideas?
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      One of the series capacitor for a PCIe lane is most likely broken off. Or a PCIe lane is bad. Visual inspection and diode mode as always.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        did u try all output ports while on riser as first card?
                        • saken
                          • Feb 2023
                          • 18
                          • GER
                          Visually, I can't see any problem with the capacitors. Yesterday i tested all capacitors (above PCIE) with Multimeter in Diode Mode. Iam not sure if i did it rigtht. Black measuring tip to ground and red measuring tip to the capacitor. All capacitors dropping to 0.6V.
                          • saken
                            • Feb 2023
                            • 18
                            • GER
                            Yes i tested already all outputs, no picture .
                            • saken
                              • Feb 2023
                              • 18
                              • GER
                              I was wrong. To be honest I can't remember. So i tested it again...and i get a picture with RiserCable and only the GTX670 connected, see screenshot below.
                              And something crazy after this, i tested the GTX670 directly connected to the mainboard and got a picture too. Only x8 instead of x16. After 15 minutes the picture freezed.
                              Soo...wheres the problem?
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3627
                                • slovakia
                                check capacitors/resistances on 9-16pcie lines
                                • saken
                                  • Feb 2023
                                  • 18
                                  • GER
                                  In order to get a better overview, I have written down all the values of the diode mode.
                                  Number 15 has the lowest values. Number 10 has the biggest difference. See Screenshot below.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3627
                                    • slovakia
                                    yep 15 can be problemtic. try to replace capacitors, but it is connected directly to GPU so if it not help only thing is reball or replace chip. But 8x gives u maybe even same performance as 16x
                                    • saken
                                      • Feb 2023
                                      • 18
                                      • GER
                                      I will do that. But there must be something else. Because i got only one time a picture with x8 connection. Most time i get no picture and i dont know if this can be only from number 15.
                                      • DynaxSC
                                        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                        by DynaxSC
                                        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                        General test conditions:
                                        - Tested with Core i5 6500 and Core I7 6700K - no difference
                                        - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                        What is wrong:
                                        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                        03-21-2025, 06:23 PM
                                        Thermal pad thickness for various laptop GPU / Graphics Cards
                                        ASUS Dual RTX 2070 OC 8GB
                                        ASUS ROG STRIX RTX 3080 OC
                                        ASUS ROG STRIX RTX 3090
                                        ASUS TUF Gaming RTX 3080 OC Edition
                                        ASUS TUF GTX 1660 S-O6G GAMING
                                        EVGA RTX 3060 Ti XC GAMING 8GB
                                        EVGA RTX 3060 XC GAMING 12GB GDDR6
                                        EVGA RTX 3080 FTW3 ULTRA GAMING
                                        EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                        Gainward RTX 2080 Phoenix GS Specs
                                        Gainward RTX 3070 Phoenix 8GB
                                        Gainward RTX 3080 Ti Phoenix
                                        GIGABYTE AORUS RTX 3080 MASTER 10G
                                        02-09-2024, 08:08 AM
                                        A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                        by momaka
                                        More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                        And a shot of the label:...
                                        01-26-2022, 03:26 AM
                                      • nikovmiroslav
                                        Gigabyte A5 X1 Need Bios
                                        by nikovmiroslav
                                        Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                        Gigabyte A5 X1
                                        From motherboard:
                                        S/N: 1TNH55ER1350895
                                        P/N: 6-77-NH55ERQY-D02-2CGB
                                        On sticker from the back of the laptop:
                                        S/N: SN21351J000657...
                                        08-24-2025, 09:15 AM
                                        Gigabyte 7X Notebook Specification for Upgrade or Repair
                                        This specification for the Gigabyte 7X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7X boardview and 7X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte 7X Notebook is accurate,...
                                        09-07-2024, 07:19 AM
