motherboard onboard VRM controller chip fails?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8696
    Is having the VRM controller chip fail (without the mosfets failing) common on motherboards?
    I think i found one of my boards with one high probability failure, and another suspected failure... both boards don't give vcore anymore... (both S775 boards incidentally...)
  • corl45
    • Jun 2018
    Re: motherboard onboard VRM controller chip fails?
    Unfortunately I am not sure how common this failure mode is. But I do have a board that has symptoms of of VRM issues but all the VRMs themselves are checking out. Can you confirm what tests made you think the VRM controller failed?
      master hoarder
      • May 2008
      • 12170
      Check if the VRM controller is getting its Enable signal.
      Could also be bad BGA under the 775 socket - fairly common if a stock Intel push-pin heatsink was used, since they tend to warp the shit out of any motherboard (not that s478 or AMD's 754/939/AM2/AM3 stock heatsinks don't, but they usually aren't as bad.)
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8696
        hmm trouble there seems to be something leaky on vcore and it didn't seem like it was the mosfets. Not sure what else is connected to that vcore wire when the cpu's not installed...
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          for me, its my socket 478 875p chipset boards and one s939 asus a8v board.
          the s478 875p chipset boards give a too low value for vcore on power on. the cpu vrm output reads 0.33v to 0.35v on one board (asus p4c800-e deluxe) and 0.87v on another board (msi 875p-neo2 and asus p4c800 non-deluxe). it always gives this vcore voltage reading regardless of the cpu inserted so its the vrm regulator. i dont think the socket is bad because i've never used the stock intel heatsink on the board. i've used a third party cooler which doesnt warp the hell out of the board. it also has a backplate regardless, so it shouldnt mangle the socket at all.
          while another s478 875p chipset board (abit ic7-g max II) randomly powers off by itself after running for a few minutes. not sure whats causing it. its not the psu because i swapped the psu but this issue still persists. the psu can still power a s775 quad core system so its not the psu, its the board.
          for the s939 a8v board, the vcore randomly starts decreasing after a few mins after power on, until the vcore reading is too low, it hangs the system & cpu because its too low. not sure whats causing it, bad caps on the cpu vrm or a bad vrm regulator. sometimes, the opposite happens, i see the vcore reading go higher and higher. cpu still runs fine tho. not sure if it will fry the cpu. also sometimes, the board randomly powers off itself when i keep pushing the reset button over and over again to try to get the system to post when the vcore is too low.
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • baletak
            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
            by baletak
            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
            I have updated laptop model number.
            1) I did not find the way to update laptop serial number - I have this one.
            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
            Hope to find someone to help me with this as I am hitting dead end at the moment.
            Many thanks
            Miro
            05-23-2025, 01:21 AM
          • CapThatBrass
            RT809F Chip Write Failure - Winbond 25R256JV
            by CapThatBrass
            I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
            I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
            The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
            10-04-2022, 11:56 AM
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
          • Troystain
            Help EZP2023+ updated chip database for w25q256jveq?
            by Troystain
            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
            I need to add w25q256jveq chip but I do not know what data should I type.
            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
            11-25-2024, 12:53 AM
