Hp Elitedesk 800 G2 bios serial change
  • bruce35
    • Mar 2022
    • 41
    • turkey
    ORIGINAL NOW CZC6287C4G
    CHANGE TRF61108NK (WRITE THIS SERIAL NUMBER)
    • 21150
    Re: Hp Elitedesk 800 G2 bios serial change
    Try HP Bios Config Utility https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
    • bruce35
      • Mar 2022
      • 41
      • turkey
      Originally posted by SMDFlea
      Thanks.but BiosConfigUtility64 not working
      • anba
        • Sep 2020
        • 7
        • morocco
        you can write the serial number in the ticket
        • reformatt
          • Feb 2020
          • 1417
          IIRC, the Manufacturing Programming Mode is locked so you need to unlock it first to use the Bios Config Utility (which is no longer supported BTW by HP but still works).
          In the past on these models, I've just dumped the EEPROM and edited it manually. Can't remember if the HP DMI tool works on these models or not to unlock the MPM. If you use a vanilla BIOS from HP, the MPM is unlocked but you need to insert all the DMI data back in, in addition to the MAC addresses for the network adaptor.
