Properly connecting power to the motherboard
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I have a brand new motherboard Asus TUF X570, that I just installed into chassis. Now I need to connect the power connectors properly. There is thing that confuses me and I want to double check, because I don't want to make any mistake.
    Please have a look at the attached picture. This is extract from the manual. While 24 pin connector is obvious on the right hand side, EATX12V2 and EATX12_1 are not that obvious. I pretty sure it is power supply for the CPU. Now, from the PSU there are both 4 pins and 8 pins connectors. Normally, motherboards have only one of the type, but this has two. Should I connect both connectors from the PSU, or only one? The manual says that user should not connect only 4 pin connect but either both or only 8 pins. This will be a gaming PC, so I don't know why there is an option to choose.
    I guess if the premium GPU card is used, then both connectors are needed.
    Maybe the question is stupid, but better safe than sorry.
    Thank you!
  • Yolofolkss
    • Oct 2019
    • 30
    • Philippines
    Re: Properly connecting power to the motherboard
    This question is not stupid, if you're only using a low-power processor and have no plans on overclocking 1x CPU 8 pins on EATX12_1 is fine.
    But if you are using a higher-powered processor and have plans for overclocking it is recommended to plug in both EATX12_1 and EATX12_2
    Keep in mind: Max continuous power on one CPU 8 pin is 235w, while one CPU 4 pin is 135w
    so if you have a high-power processor or overclocked one that is near 200w it is better to put both EATX12_1 and EATX12_2.
    Edit: This might be obvious but make sure to plug the right cables, mostly on a modular PSU. switching them may have bad effects.
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Thank you Yolofolkss,
      good to know these numbers. Yes, I do have modular PSU and I connected the cables with great caution.
      • FZG
        • Sep 2022
        • 111
        I would always connect both cables, even if you currently use a low powered CPU. If you switch to a more demanding CPU later on, the cables will already be routed and you won´t have to take out the mobo again.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          +1
          If you have the cables on the PSU, might as well use them. It won't hurt anything.
          • ResoluteHawk
            Connecting an LVDS/eDP cable into a live motherboard
            by ResoluteHawk
            Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
            Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
            I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
            Yesterday, 04:39 PM
          • glovecaps
            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
            by glovecaps
            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
