Ethernet Controller 8S661FXM-RZ P4 and mssing cap values
  • seanc
    • Nov 2008
    • 1319
    #61
    Re: Ethernet Controller 8S661FXM-RZ P4 and mssing cap values
    I don't know if it would work with a buzzer soldered in, I've never tried it, feel free to have a go.
    Is it set to use onboard VGA as primary video in the BIOS?
    If not, what happens if you put the cards in and boot into Windows? Are they detected? Does anything get detected in the expansion slots?
    • briztech
      identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
      by briztech
      Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
      07-25-2024, 06:18 AM
    • master3112
      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
      by master3112
      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
      10-29-2024, 09:32 PM
    • proxneo
      Recapping Sony ICF-SW55 - verifying cap values
      by proxneo
      Dear reader
      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
      At the moment, I have selected replacements based on the following list of values:
      3 x 470uF 10VDC
      3 x 4.7uF 35VDC
      4 x 47uF 50VDC
      8 x 22uF 6.3 VDC
      1 x 220uF 6.3VDC
      5 x 100uF 6.3VDC
      Which...
      06-21-2023, 12:38 AM
    • Spikeman
      Dell Precision 3440 support for CPU 11th gen
      by Spikeman
      Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
      I ask you if it is possible to add the correct microcodes for the Precision 3440.
      I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
      Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
      03-11-2025, 09:54 AM
    • madan1
      Cisco catalyst 2960c POE
      by madan1
      Hello everyone.
      Got a catalyst 2960 from the usual scrapyard - ebay.
      It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
      Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
      Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
      The switch fails to boot due to the following POST error:...
      12-19-2024, 09:34 AM
