broadband ut300r2u modem,link light stays on forever
    • 31024
    Re: broadband ut300r2u modem,link light stays on forever
    why is a capacitor on long wires? that wont work properly.
    • playit
      • Feb 2020
      • 182
      • india
      oh they are new capacitors ,so thier legs are long, i dint cut them yet, the voltages are ok tho.
      • playit
        • Feb 2020
        • 182
        • india
        i need help in this putty thingy, this time i soldered the joints somehow, when i connect rxd from usb to any of the pins in board ,it keeps running some grey boxes 'i tired all the speeds ',when i connect gnd to gnd ,it stops , nothing comes even when i power up. i kept utf 8,still nothing readable comes. should i alter some of voltages they say in some forums ? i have no idea how to make this work.. i just atleast want to see what this modem boots ,have any one tried to see boot from ch341a in ttl mode ?
        also cant type anything in putty terminal
        my adapter for the modem is 5.2 v , and ch431a is black edition with gold color.
          • 31024
          https://wonghoi.humgar.com/blog/2021...based-routers/
          • playit
            • Feb 2020
            • 182
            • india
            so i cant work out with this usb programmer ?
              • 31024
              the programmer is fine, use the link for the putty settings
              • playit
                • Feb 2020
                • 182
                • india
                #27
                oh yes putty settings are ok, i kept the speed, utf8 code . by the way now i checked usb rx tx interchaged within it, and typed in putty, it showed clearly what i typed. they call it echo test i guess.i thought to fix this with soldering, but i am not sure whats happening, i soldered gnd to gnd , then i touch rx of usb to pins on modem, nothing comes up in putty , but if i take off the gnd to gnd, then rl will read continuous of any pin i touch. ofocurse with that grey garbled readings.what this means ?
                  • 31024
                  you must have gnd connected.
                  and rx.
                  • playit
                    • Feb 2020
                    • 182
                    • india
                    #29
                    " i soldered gnd to gnd , then i touch rx of usb to pins on modem, nothing comes up in putty" i dont know which is rx or tx or vcc pin in my modem. so i touch all other 3 pins ,but nothing shows up in putty .. what is the problem ?
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #30
                      Originally posted by playit
                      i managed to connect the ch341a to board, but no matter what speed i keep in putty it shows gibberish characters, no english.
                      Post the output you do get in PuTTY with CODE tags, maybe something can be understood from it.
                      • playit
                        • Feb 2020
                        • 182
                        • india
                        #31
                        i thought i connected it right , actually that time i think i connected rx of usb to some rx or tx of board, gnd of usb to vcc pin in board, so it went on reading gibberish faster non stop , but this time i learnt what is gnd in board so when i have posted in above post that nothing happens when i connect gnd to gnd , rx of usb to rx or tx of board. if i take disconnect gnd to gnd , then gibberish characters will come again , if gnd is connected back, it will stop.
                        what is code tag.. i dono what its..
                        • playit
                          • Feb 2020
                          • 182
                          • india
                          #32
                          if you look at top of the pic, those black grey boxes is what i see a lot when i connect only rx of usb to any pin in board. but when i connect gnd to gnd , then it would stop.
                          • playit
                            • Feb 2020
                            • 182
                            • india
                            #33
                            this is a example of a pic , not my own, i have kept all the speeds and cheked , its the same characters.
                            • playit
                              • Feb 2020
                              • 182
                              • india
                              #34
                              i took rcx of usb , connected to all 4 pins in board with power off modem, then i see slower grey boxes coming in 3 pins except one. when i power on the input in putty comes faster same grey boxes with some letters.
                              Code:
                              ▒▒▒▒▒▒▒▒{▒▒▒}▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒|▒▒▒▒▒▒▒▒▒▒?▒▒▒▒U▒▒?▒▒▒▒7▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒݅▒▒▒_▒▒▒▒▒▒▒▒ߝ▒▒}▒▒▒▒▒▒▒▒{▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒{▒▒▒▒▒▒▒▒▒▒▒▒▒▒ݺ▒▒▒߹▒~▒▒▒▒▒▒▒▒ߍ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒{▒▒▒▒ナ▒▒▒y▒{ߕ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒i▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒}݇▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߽U▒▒▒o▒▒▒▒▒▒▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒▒▒▒▒▒sߐ▒▒▒▒▒▒▒▒_▒▒߿▒▒▒W▒▒▒▒▒ݽ▒▒▒▒▒▒▒▒▒߷▒}▒߁▒▒▒s▒▒▒▒▒ż▒▒▒▒▒▒߿▒▒▒Q▒▒▒▒▒߿▒▒▒▒▒տ▒▒U▒▒▒▒▒▒▒▒▒▒▒▒▒▒o▒՟▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒ݕ▒▒▒▒▒▒▒▒▒▒▒▒▒t▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ۿ▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒▒▒ݰ▒▒▒o▒▒▒߽▒▒▒▒▒▒▒▒▒▒▒▒▒▒߽▒▒▒▒]▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒o▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒s▒▒▒W▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ݿ▒▒▒▒▒▒?▒}▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ߟ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒t▒▒▒▒▒▒۾▒▒▒▒▒_▒▒▒▒▒▒▒▒s▒▒▒▒ߤ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ߥ▒▒▒▒▒▒▒▒▒▒▒ŕ▒▒▒▒?ߠ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߼▒▒▒▒▒▒▒▒▒▒ݽ▒]▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒{▒▒▒{▒▒▒▒▒▒▒▒▒▒▒▒ߵ▒▒y▒gݽ▒%▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒o▒ߝ]▒▒▒՟▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒ߞ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5▒▒▒▒▒▒▒▒▒ݽ▒▒▒▒▒▒▒▒ѝ▒▒▒▒▒▒▒▒▒ߗ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒7▒▒▒▒▒▒▒▒▒▒ߑ▒W▒▒▒ߝ▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒A▒▒▒ߕ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒݁▒_}▒▒߽▒▒▒▒󿹕▒▒▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒▒|▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߯▒▒▒▒ݝ▒▒▒ߝ▒▒▒▒▒▒▒▒7▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒o▒▒▒▒▒▒▒▒▒▒▒▒E▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒]▒▒▒▒▒w▒▒▒▒▒▒▒▒߅▒▒▒▒▒ݕ▒▒▒▒▒▒▒▒▒▒▒▒▒ǿͿ▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒▒▒▒▒o▒▒▒▒▒▒▒▒▒▒▒П▒▒▒▒▒▒▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ߠ▒Ͽ柿▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒1▒▒▒▒▒@▒▒͟߿▒▒▒▒▒▒▒▒E▒▒▒▒▒▒▒▒▒▒▒▒߼▒▒▒▒▒▒P▒ݟ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒t▒▒[▒7o▒<▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒ſ▒▒▒▒▒▒▒ݿ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒3▒}▒㿿▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒s▒▒▒▒▒▒▒▒▒▒▒ݾ▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒u▒▒▒▒▒▒@▒|▒▒▒▒▒▒@▒▒▒▒▒`▒▒▒▒▒▒_▒▒@▒▒▒▒▒▒Ģ▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒▒▒▒▒߿▒▒▒w▒▒ѐ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߽▒]▒▒▒▒▒▒▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒U_▒▒▒▒▒▒▒߿▒▒́▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒9▒▒▒▒ߊ▒▒▒▒▒E▒▒▒▒▒▒՟▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ߛ▒▒▒ݕ▒▒▒▒▒▒▒▒▒▒▒▒▒▒pݿ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒y▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Ͽ▒▒▒}▒Ѱ▒▒߽▒▒▒▒▒▒▒▒ݷ▒▒▒▒▒▒▒`▒▒▒▒▒▒▒▒▒▒▒▒▒▒57▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒՟_▒▒▒▒▒▒▒▒▒~▒▒▒▒▒▒▒▒▒_▒▒߼▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5▒▒▒▒▒▒▒~▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒ޕ▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒Q▒▒߮▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒}▒▒▒▒▒▒▒ď▒▒▒▒▒▒u▒▒▒▒▒▒_▒▒▒▒▒}▒߿▒▒7▒▒▒▒▒▒▒p▒▒▒?▒▒▒▒ݽ▒▒}▒▒▒▒▒▒▒w▒ݿ▒▒q▒▒▒▒▒▒▒▒▒Ք}▒▒▒t▒▒▒▒▒▒U▒▒▒▒▒▒▒▒▒▒▒▒▒▒տ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒@7▒▒▒߽▒▒▒=▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒A▒ݝ▒▒▒▒▒▒ߙ▒▒▒▒߿▒▒ߵ▒▒▒▒▒▒▒▒▒▒▒ո▒ݿ▒▒▒▒▒ǟ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Ѵ▒▒▒▒ߜ_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ϱ▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒8▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5▒▒▒▒▒▒▒▒߹▒▒▒o▒▒▒▒ݿ▒▒▒▒▒t▒▒▒▒▒▒▒▒▒ױݿ▒▒▒▒▒▒▒▒|▒▒o_?▒▒▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒_▒▒Ͽ▒▒▒▒ϵ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ܗ߿▒▒▒▒▒▒▒е▒▒▒▒▒▒▒▒_▒▒▒߀▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒g▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߾▒▒▒▒▒▒▒▒▒▒▒▒ӿ▒▒▒▒▒]7▒▒9▒▒▒▒▒▒▒▒t▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒տ▒▒▒▒PΟ▒▒▒▒▒▒▒▒ٽ▒▒▒▒▒▒ı▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒׿▒▒▒ߵ▒▒▒▒▒▒▒5▒▒▒▒▒▒▒▒߿▒▒_▒▒▒ݾ▒▒ݽ▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒չ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒_W▒▒▒▒▒▒▒▒~߿▒▒▒▒ߗ▒▒▒▒▒▒▒▒▒t▒▒▒▒▒▒▒▒▒▒▒▒͵▒▒▒▒▒▒▒▒▒߿߸▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒m▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒_▒▒▒퀣▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒|▒▒▒▒▒▒▒▒▒▒Q▒▒߽▒▒▒▒▒ݗ▒▒?▒▒▒▒▒▒▒▒▒{▒▒▒▒▒w▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒P▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒ߑT▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒7▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ݷ?▒▒▒▒▒7p▒▒p▒▒▒▒U▒ܿ▒▒▒▒▒▒7▒▒▒▒▒ѝ▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒Եݿwߛ▒▒▒▒▒t▒▒▒w▒▒ߕ▒▒▒▒Uߑ▒▒▒▒▒_▒▒▒▒▒ߏ▒▒▒?▒▒▒▒▒߱▒▒▒▒▒▒y▒▒▒|▒ߵݵ▒▒▒▒▒▒▒?▒▒߁▒▒▒▒߿[▒]▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Wߜ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒=▒▒ߵ▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒5▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5▒▒▒߿▒▒▒▒▒}▒▒▒▒߽▒▒▒▒▒▒ŕ▒▒▒▒▒_▒▒▒▒▒▒▒▒▒▒׿▒▒▒▒▒▒▒▒▒▒▒▒▒ӽ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5▒▒▒▒?▒▒▒▒▒▒▒▒ݿ▒݁▒▒▒▒?▒▒▒▒▒▒▒▒▒▒[▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒U▒▒▒▒ן▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ߵ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒]▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒▒߾▒▒▒▒▒▒▒▒▒▒U▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒߿▒▒▒▒▒▒▒▒ͯ▒?▒▒t▒▒▒▒▒▒▒▒{▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒ӿ▒▒▒Uݕ▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒a▒▒m▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒Ѹ▒▒▒▒▒ݟ▒߽▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒U▒▒▒▒▒▒▒k▒▒▒▒▒▒▒▒▒▒▒▒ؿ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒|_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒4▒▒▒▒▒▒ݷ▒ݸ▒▒u▒▒▒▒▒▒▒▒5▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒O▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒إ▒▒▒?▒▒▒▒▒▒▒▒▒▒}ܿ▒▒▒▒▒▒▒▒▒ս▒▒▒▒׿▒▒▒E▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒ݽ▒?▒▒}▒▒▒տ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߽▒q▒▒▒▒▒▒▒▒▒▒C▒▒▒▒▒▒ÿ▒▒▒ѹ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ŵ▒▒▒▒▒▒߿▒▒▒▒▒▒ݕ▒▒▒▒ݷ▒▒▒▒▒▒▒▒▒▒߽▒▒▒▒▒▒▒▒▒͕ݿ▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒A▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒߿▒▒?▒▒׿?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ս?o▒▒▒▒▒▒߿▒߾▒▒▒▒▒▒▒▒_׷▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒}▒▒|▒▒▒w▒]▒▒▒}▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ݴ▒▒▒▒▒▒▒▒Y▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒▒`▒▒▒▒▒9▒▒▒?▒▒▒߿▒wݳ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿ ▒▒▒]▒▒▒▒▒▒▒▒ߕ▒▒▒▒]▒?▒▒▒▒▒▒▒▒▒▒▒՟▒▒▒▒▒▒▒}▒▒}▒}▒▒?▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒}▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ߍ▒▒?▒▒▒▒▒▒▒▒▒▒;▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒t▒▒▒▒▒▒▒▒▒▒Խ?▒▒▒▒▒▒▒߁▒▒▒▒▒▒տݢ▒▒▒▒▒▒▒W׿▒▒▒▒ݻ▒▒▒▒▒▒▒▒5▒▒▒▒▒▒▒߿▒▒_▒▒▒▒▒▒▒▒▒▒߰▒▒▒▒▒▒▒▒▒9▒▒▒▒5▒▒߿▒▒▒▒▒▒▒▒▒▒▒▒Ŀ▒▒}▒▒▒▒▒▒▒▒▒ս▒▒▒▒▒▒}▒▒▒??▒▒▒D▒▒▒▒▒▒▒?▒▒▒▒▒▒߿▒▒▒▒▒߿▒▒▒▒▒▒|▒▒▒▒▒▒▒ݹ▒▒▒▒▒▒▒▒▒▒▒=▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒=▒▒▒▒▒▒▒▒▒5▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒▒▒▒▒▒▒׿▒▒▒▒▒?▒▒▒▒▒▒▒▒▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Օ▒▒▒▒▒▒▒▒▒▒ߜ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒Ձ▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒U▒}?▒]▒▒▒▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒ף▒߿▒㳁▒▒▒?▒=▒▒▒▒▒▒{▒▒▒▒▒▒▒㡵▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒߿▒▒▒g▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒㿿▒▒▒▒Ԕ▒▒▒▒▒▒U▒▒▒▒▒u▒▒▒▒▒▒▒_▒▒▒▒▒_▒▒▒▒▒w▒▒▒▒▒▒▒ݰ▒▒▒▒▒▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒▒▒▒▒▒▒▒▒u▒▒▒▒▒tu▒▒▒▒▒▒▒5▒▒▒▒▒U▒▒▒▒@▒▒?▒▒▒▒▒▒▒▒▒▒|▒▒▒ÿ▒▒▒▒▒▒▒ŗ▒▒▒▒▒▒▒▒ݔ▒▒▒Ͽ▒▒▒▒▒▒▒▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒P▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?t▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
                              when i touch the gnd of usb to gnd of modem it will stop.
                              • playit
                                • Feb 2020
                                • 182
                                • india
                                #35
                                i watched forums and video about 3.3 v /5v difference - i just checked the voltages of ttl pins in usb, it was giving 4.8 v ,so this might be creating problems.. should i mod ?
                                • playit
                                  • Feb 2020
                                  • 182
                                  • india
                                  #36
                                  i even modded it now, getting 3.28 v in rx tx pins in programmer.. but its the same result.. only rx - to serial pin in modem gives unreadable inputs ,if gnd is connected along with rx of programmer - the input will stop. nothing comes. blank putty as well other terminal softwares. hope anyones having any idea.. thank you.
                                  • playit
                                    • Feb 2020
                                    • 182
                                    • india
                                    #37
                                    Originally posted by boyebaran
                                    pls change crystal oscillator of cpu.(with original bios) and test
                                    seems that it is not bios problem .
                                    if changing crystal no change you can resold cpu carefully
                                    oscialltor crystal i changed today, its the same result, the lan light on off cycle. as you said to desolder cpu , i will try it but i dont have any solder balls or paste, can i just heat it again , i have did it before too.. but it was the same result
                                      • 31024
                                      try changing the baudrate in putty to 115,000
                                      • playit
                                        • Feb 2020
                                        • 182
                                        • india
                                        #39
                                        its the same result with that speed too. if gnd and rx is connected, there wil be no input. when rx alone is connected the reading will be fast filling in. but unreadable.i checked with all speeds. with both gnd and rx various combos, its the same result. nothing will come if gnd is connected.
                                        • playit
                                          • Feb 2020
                                          • 182
                                          • india
                                          #40
                                          would this be my problem too. the on off cycle of lan port same as mine ..lightening spoiled port - https://www.youtube.com/watch?v=GeLpQo-HwAo but sadly i have only lan port even i wanted to pry that transformer off
                                            Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                            by sam_sam_sam
                                            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                            I also have back when Light of America had these light bulbs available for yard lights
                                            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                            While the Lithonia lighting fixture has all most certain bulb failure
                                            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                            I have only had this light fixture for not more than a year if it...
                                            07-02-2023, 03:45 PM
                                            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
                                            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 09:10 PM
                                            09-06-2024, 08:40 PM
                                          • serious_electron
                                            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                            by serious_electron
                                            Hello Everyone!
                                            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                            06-28-2025, 02:57 PM
