VeloCloud Edge 520 Problem - Unable to boot
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I have a VeloCloud Edge 510 that worked perfectly. I was able to install PfSense on simply by plugging into the console port and installing PfSense from a USB flash drive.
    Now I got an Edge 520 and I'm having a problem. I get this on the console output and it just keeps doing this:
    https://pastebin.com/Q0mNCLQC
    Any ideas?
    • 31111
    Re: VeloCloud Edge 520 Problem - Unable to boot
    strange.
    one thing i did notice,
    replace the battery and set the clock.
    you cant be running a unix-based o.s. with the clock saying it's 2018.
    the journal entry will be newer and the filesystem will panic and stop.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Originally posted by stj
      strange.
      Huh, very very interesting. I didn't even notice that. Than kyou.
      But I tested the battery and it's not completely dead, 2.8V. If we have any CR2032s at work that haven't been stolen i'll get a replacement anyway. How on earth would I set the clock though, hmmm...
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        strange.
        Wow, I found part of the problem. I switched from PuTTy to Tera Term and it's going a lot further. I can get into the Pfsense installer. But it eventually crashes before I can finish.
        Edit: I thought maybe it was a power issue. I was using a 12V 3.33A power supply from an Edge 510 even though the 520 asks for a 12V/5A power supply as per the label. However I connected it to a 500W ATX PSU and it's not any better.
          • 31111
          terminal making a difference is strange.
          is it passive or can you enter commands?
          "date" or "time" for example?
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            i can interact with it... f12 for boot menu, pfsense installer, etc.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              OK, I have an Edge 510 and two Edge 520s, all of them crash. One of them I managed to get pfSense to install but after getting to the web UI it crashes after a couple minutes. That's the Edge 510. Both the 520s don't even make it all the way through the installer.
              I'm pretty sure it's not a heat issue. I replaced the thermal pads on the 510 and one of the 520s and then went a step further and added a fan on the same 520. The other 520 I have never even opened up.
              I don't understand what's wrong.
                • 31111
                bad power?
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  bad power?
                  Negative. I've tried four different power sources.
                    • 31111
                    bad power on them - from shit caps?
                    got any pics of these ?
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Sure, I'll post when I get home
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        This is one of the 520s. I even added a fan haha.
                          • 31111
                          not much to see is there!
                          i wonder what that big cap does!
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Yeah, I am not sure... the 510 doesn't even have the big Elite 25v 15000uF... I've attached some pics of that one.
                            My second 520 seemed to boot up fine with the stock firmware. When I first got it I connected to the console and let it sit for a few mins. It worked fine. Then I attempted to install pfSense. Couldn't even make it through the installer without crashing. Got far enough to erase the stock firmware tho haha. I timed it and it's always 2 minutes on both of them before it crashes/reboots. Even the one I took the heatsink off, put a different thermal pad, and taped a fan to. And on the 510 it's always 5 mins to crash/reboot. Both the first test boot of the morning after it sat all night and the second time right after that.
                            I'm so lost and confused.
                              • 31111
                              no crash logs?
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                no crash logs?
                                not really it seems like a hard reboot and its os-independant. whether i leave it sitting on boot menu, let it boot to usb, etc.
                                i'm so confused why it's exactly 5 mins on the 510 and 2 mins on the 520...
                                  • 31111
                                  a hardware watchdog circuit thats not getting updated?
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    That's what I'm starting to think. I have an Edge 500 on the way as well, I'm going to play with that one and see if it too has the same thing.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      OK, so I played with an Edge 500, which is a totally different setup. It's just a typical Atom mini-PC. Stuck my mini-PCIe VGA card in there and it has a real BIOS and everything. Happily installed Win10 on a 64GB mSATA SSD.
                                      So yeah, it's gotta be a watchdog timer but without an easy way to access BIOS on the Edge 510 and 520 what do I do? I'm determined to continue working on this project until I either get mad and just screw them back together and sell them on eBay again or I get it to work haha.
                                        • 31111
                                        maybe the official o.s. has the service routine to hold the watchdog back.
                                        do you have an install image?
                                        • futadmytro
                                          Asus g713qm-es94 stuck on boot bios problem
                                          by futadmytro
                                          sn^M4NRKD02753616E
                                          MB- g533-6050a3250201-MB-A03
                                          Stuck on boot after ROG logo, did not enter to bios
                                          In flash bios , laprop boot but have video issue
                                          orig bios...
                                          06-25-2025, 08:07 AM
                                        • mpower1226
                                          Dell optiplex 7090 boot problem
                                          by mpower1226
                                          Hi masters, need your help in solving this mystery.
                                          i have a dell optiplex 7090 micro that i bought from local kijiji.
                                          when i turn it on, error comes out saying no hard disk.
                                          i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
                                          i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
                                          it seems as if the computer doesnt recognize the ssd...
                                          01-22-2024, 10:37 PM
                                          LENOVO ThinkCentre Edge 71 ThinkCentre Edge G630 Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          LENOVO ThinkCentre Edge 71 ThinkCentre Edge i5-2400S Specification for Upgrade or Repair
                                          LENOVO ThinkCentre Edge 71 SFF ThinkCentre Edge G630 Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
