Synology DS418play need to locate a tps65094 replacement
  • ligym60
    • Oct 2016
    • 39
    Hi I recieved a synology disk station yesterday with a no power fault. Witty shorts on multiple power rails. After dividing the power rails. I've narrowed it down to this tps65094 chip having dead shorts on buck converter 2, 3, 4. After lifting the chip from the board all shorts vanish. Testing the chip itself it has shorts on these rails. Mouser has a 52 week lead time and digikey has 0 in stock. Does anyone on here have a distributor that offers them ? Some have stock but only sell a minimum of 2000pcs :/ I would like to purchase 2-4pcs
    Thanks everyone for your continued support.
  • ligym60
    • Oct 2016
    • 39
    Re: Good morning everyone in need to locate a tps65094 replacement
    Here is a edited version of data sheet with highlighted faults if it helps anyone
    • ligym60
      • Oct 2016
      • 39
      No worries
      Found a supplier that will send me 2 of these
      Thanks everyone
      • KYBOSH
        Samsung UN55HU8550F - No picture, No sound
        by KYBOSH
        Previous owner says this unit powers on and sometime has an image and sometimes not. They attempted to replace the main board but with no success.
        TV came with the replacement mainboard as well as the original.
        When the TV turns on there is no image or sound. No response to the remote or toggle button other than the power button. The power supply's relay was clipping here and there. It did that for several seconds even after I removed the mains. I did this even with no other boards connected (only the backlight was connected at the time). Backlight looks fine but...
        01-09-2023, 02:36 PM
      • skwarszczow
        Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
        by skwarszczow
        This is my first post on the forum
        I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
        Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
        Before completing the purchase, we decided to erase...
        03-23-2025, 06:04 PM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • WVUfan
        PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
        by WVUfan
        hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
        08-11-2025, 01:12 PM
