Broke IPv4
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Broke IPv4
    Hi!
    Never mind, I fixed it. I really need to get Symantec Endpoint on here and do away with this crappy "Advanced" Windows Firewall! I'm tempted to install one of our 5 licenses for Norton on here, but I think that goes against the EULA. It was just a stupid mis-configured Windows firewall rule.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Hondaman
    Hardware firewall to block ad servers?
    by Hondaman
    I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
    The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
    02-05-2025, 05:04 AM
  • nerdmafia
    Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
    by nerdmafia
    Hi first question posting here, but no need to go easy on me!
    I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
    05-21-2025, 09:39 AM
  • juergenb
    Sophos XG86w Firewall forgets the date and time as well as the DMI environment variables after power cycle
    by juergenb
    I have a small Sophos XG86w firewall here, which is still working so far. But there is a problem with the BIOS and the DMI environment variables.
    The hardware forgets the date and time after a reboot or a power failure.
    The DMI environment variables are also reset to default values.
    I have now tried 2 different batteries (CR2032).
    I reset the DMI vars via an EFI shell and with AMIDEEFI64 (v5.21.0057).
    However, after a reboot or a power cycle, these values are reset again.
    It is an Apollo Lake platform with an Intel...
    10-08-2024, 04:19 AM
  • trex66
    Craftsman 82345 Multimeter broke!
    by trex66
    My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
    03-04-2025, 04:26 PM
  • Jamey021
    Yep...I broke it MOAR after fixing it. a2681 MacBook Air
    by Jamey021
    So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
    Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
    Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...
    01-22-2025, 05:22 AM
