Netgear DG834GV - bad CapXon units
  • japlytic
    • Oct 2005
    • 2086
    In the Serviceman's Log in Silicon Chip, March 2009, there was a wireless ADSL router with bad capacitors (two 330uF 10V units). They appeared to be general-purpose units.
    Replacing these capacitors fixed the problem.
    There was also a "Mailbag" letter in the same issue about bad electrolytic capacitors.
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Netgear DG834GV - bad CapXon units
    I wonder if the issue will ever truly be brought to light.
    It would be great if we started seeing japcaps all over the place again. I was looking in some new Yamaha receivers at the store and they all had Jamicon caps in it. Very unlike Yamaha to make cheap crap like that
    • gripa
      looking for netgear WN2500RP schematic
      by gripa
      I am looking for a schematic of the netgear WN2500RP repeater.
      best regards
      12-17-2024, 12:39 PM
      by momaka
      03-15-2023, 10:17 PM
    • greatdragon
      Looking for schematics for Netgear Nighthawk c7500
      by greatdragon
      The markings on the board say
      tmt YAML 1 94V-0
      e114139
      1806
      03-20-2025, 11:58 AM
    • czacha414
      Few units of Lenovo Thinpad t490s had the same `backspace` and `enter` keys issues
      by czacha414
      Guys, I need your help. I have an issue with Lenovo T490s laptops – several dozen units in different configurations, and in about half of them, the same problem appeared over time. Specifically, the Enter and Backspace keys don't work unless they are held down for a few seconds or pressed slightly harder than usual. Once they start working, they continue to function until the next reset. However, this is not just a Windows issue – it occurs under other operating systems, in BIOS, and during POST as well.
      While searching for information, I found many threads describing the same...
      12-27-2024, 01:41 AM
    • shovenose
      Netgear JGS516PE Switch Fan Replacement
      by shovenose
      I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
      It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
      Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
      I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
      Instead of spending $30 on the correct replacement fan, does anyone have a clean...
      12-12-2024, 03:24 PM
