Re: Suggestions on how to CAT6, CAT3 and RG6
Thank you guys for correcting me. I could have sworn it was 45V during the ringing but I must have been wrong. Perhaps I was trying to light one of those old incandescent light bulbs, the ones that run off AC. I remember it only got bright enough when the phone rang.
For PoE, are you referring to Power Over Ethernet? Just curious. Thanks!
That is 45 volts DC for on hook. The ring voltage can be as high as 110 AC. Off hook is around 20 volts DC. Usually with floating ground. The voltage drop from 45v to 20 volts lets the Telephone Company know you pick up the phone. The audio rides on top of the 20 volts DC. The ring voltage use to always be AC but now it is dependent on the company as they may put out a digital ring. Therefore some phone will not ring with some companies.Last edited by keeney123; 10-11-2016, 10:29 AM.Leave a comment:
FWIW, 48 is max for POE. But that is supply voltage, not AC bursts.Last edited by ratdude747; 10-10-2016, 09:36 PM.Leave a comment:
Is that in the UK? I could have sworn the 45v was to ring the bell and then it dropped to keep the call going. I might be wrong. We live in the US, so maybe things are different? I'll check tomorrow, I gotta get up early though so I'm going to bed. Night.Leave a comment:
90vac is the power to ring the bell - it drops to about 45v during the call.Leave a comment:
Are you sure about this? 90V seems a bit high for telephone. I thought when the phone rang, the telco sent around 40 ~ 50VDC and then afterwards, the voltage was low, around a couple volts. I seem to remember powering an LED using the telephone wires when I was in high school, just trying to have a light source when the power went out but the phones still worked (back in the days of rotary telephones). The LED wasn't very bright at all, but when the phone rang, it fried the LED. Maybe it wasn't an LED but some other type of light....I remember wiring up a telephone line and someone called and that thing shocked me. I wouldn't think DC would shock like that.Leave a comment:
To answer the original question:
The Cat6 and RG6 can be paired. I wouldn't sweat it. Cat 3 may be a different story especially if you're on a true land line phone (not VOIP/cable) which during a call will run at 90V. I've paired Cat5 and flat phone cord before but that was not knowing what I was doing. Works fine but the stretch in question was somewhat low usage as was the landline (Cable VOIP).
At work we have a few assembly lines with 120V and Ethernet in the same channel of wire trough. That's because the Cat5e (or Cat6?) we're using is rated for such (some Cat5 is only 50V or so rated). Also it's for PLC/Robot connections, and said cables are often shielded (Allen Bradley uses shielded Cat5e for a lot of their applications at least).
Food for thought/further research: Originally Cat5 (10-BaseT) was to use the center pairs as cat3 (making the plugs 100% universal), but due to interference fears that never saw much use (which is also why Cat 5 didn't have a twist spec for the center pair and why Cat5e became a thing).
Do people still use landlines from places like Verizon or does everyone just have cable modems / cell phones now? We added the telephone lines in case someone wanted Verizon. But the way we're doing it, we should be able to plug the cable modem into our telecommunications box and then eventually, when every room is done, any jack will provide a valid phone line. I think for the other rooms, we'll do the 5e. I'll probably look for some orange type 5e or something. Just gonna have to drill better holes. Maybe I should get the shielded stuff. I've never played with it before, is it harder to run?Leave a comment:
Food for thought/further research: Originally Cat5 (10-BaseT) was to use the center pairs as cat3 (making the plugs 100% universal), but due to interference fears that never saw much use (which is also why Cat 5 didn't have a twist spec for the center pair and why Cat5e became a thing).Leave a comment:
if i had to wire a house again, i would use special trunking designed to look like skirting board for the low voltage stuff.Leave a comment:
What was your idea for the easy fix for us?Leave a comment:
The proper fix is to pull the cables back and sleeve them in the EMT. Unfortunately, This should have been done when the wall cavity was changed into the return. Can you access these cables from both sides of the return duct? If so, I may have an easy fix for you.Leave a comment:
Spork - in post #13 where you show the Romex cable in the return. It was a common practice until the late 90's where the building codes were changed to stop that practice. Although it was perfectly legal until then, that installation looks newer. The white plastic staples is the giveaway.
If it's not allowed now, how do I fix it? Can I just use that 3M spray to coat the cables, like I was talking about doing when I responded to Keeney123?
It'd be a lot easier to just coat the cables than pull them all back out and run that EMT. The electrical ones, they will be extremely hard, because I don't see any junction box or anything. I think walls will have to come down or something. That wouldn't be good at all. We are not ready to tear up the floor in the hallway and we definitely don't want to take down drywall. The previous owners replaced just about all the lathe and plaster with drywall before they sold us the house. The closets still have some and some of the ceiling still has some and that will have to go, but much later in time.
Thanks.Leave a comment:
So the fireblock is used to cut down air flow which will slow the fire down not prevent spread of fire. To do that you would need brick in all the walls and ceiling and floor in every room. Make sure you have proper smoke alarms in every room, as Stj mentioned a fire extinguishers on each floor, a planned route of escape. Protect the things that matter, Human Life. Lastly make sure you house insurance will cover fire.Leave a comment:
ENT (electrical nonmetallic tubing), AKA smurf-tube, comes in bright blue or gray, depending on the manufacturer. Neither is plenum-rated. EMT is the way. Bending 1/2- or 3/4" EMT is pretty easy. You have to remember there is a deduction for your bends, regardless if they're a full 90 or just a 45. There are free apps for a smartphone that even I use for running EMT. As far as the fire sealant is concerned, I just passed an inspection using the foam-type sealant for all my vertical penetrations.Leave a comment:
Damn it all, the fireblock isn't good either. It's just designed to prevent airflow but isn't actually fire resistant or anything. For that, the all power Google recommends some product by 3M. Looks like we're purchasing the 90 degree elbows and the conduit. Thanks for the help guys!
Damn it all, the fireblock isn't good either. It's just designed to prevent airflow but isn't actually fire resistant or anything. For that, the all power Google recommends some product by 3M. Looks like we're purchasing the 90 degree elbows and the conduit. Thanks for the help guys!Leave a comment:
It's blue, like Smurfs Uniballer. Damn it all! I got horrible eye site and I read it as EMT Coil. My wife just came in and said no, it's ENT coil. This is it:
http://www.homedepot.com/p/Carlon-1-...-025/202688856
And it won't work at all, will it? What about just covering the cables with that fireblock foam spray we bought? Would that be okay?
Here's a link to the fire block:
http://www.homedepot.com/p/GREAT-STU...3992/207077797
If this doesn't work, I'm going to have to put this off until I get more money. We need a lot of 90 degree elbows and different size conduit. I'm keeping the CAT6 seperated from the rest. So, two lines for CAT 6, then I'm running the two telephone lines (cat 3) and the two coaxes together.
So, that's one conduit for one of the CAT 6, one conduit for the other CAT 6, one conduit for the two CAT 3's and RG6U. Then I have to do it all over down in the basement. The elbows add up real quick like. I figure for just one cable upstairs, I need 4 elbows. For the basement, I need I think just one elbow per conduit. That's what? 15 elbows. The ethernet ones, I was going to use the smaller conduit because it's cheaper. There's also those clamps I'd need to purchase as well.Last edited by Spork Schivago; 10-08-2016, 06:30 PM.Leave a comment:
So, instead of the metal stuff, we got EMT coil. It's a hard plastic. I think this will be fine. We also bought some fire block gel spray. I know the metal stuff would have been better, but the Home Depot guy said the plastic stuff should work just as well and it was much, much cheaper.
If I absolutely cannot use it, I'll return it and buy the metal tubing and all the ends, etc.Leave a comment:
And thanks Stj. My mind hasn't been working lately. We got fire extinguishers. In this area, we couldn't purchase the house unless the owners left one for each floor and carbon monoxide / smoke detectors per each floor. They just left them all in the basement (which counted as being okay, a little weird if you ask me!) I'll just move one upstairs but I still want to insulate the wires that I'm running at least with EMT.Leave a comment:
by Kezi GamerHi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated...1 Photo
03-24-2025, 08:37 AM -
by redwireI got gifted a Hakko 950 SMT hot tweezers but no base or stand.
Any suggestions for building one?
"The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
I don't have any of those, have a 470-2 (no RTD in) and a FX-888A. -
by CapLeakerAnyone got any Shelly remote devices around here?
I’ve got a few of these and they were all working fine for about a year. Today I noticed that one of them that controls a single light switch isn’t working at all. I mean it’s so dead, even the light switch doesn’t control the relay. No clicking, no anything whatsoever. Unfortunately it’s in the basement in a dark room and trying to get it out is going to be interesting. Maybe there is some carnage in there, who knows. It was hooked up to power mains.
The other exact same one is in the same room,... -
Does anyone have any experience with TIA-606-C labeling scheme?
Trying to label my cables properly but I'm getting a bit confused. Using a grid system, I believe part of a label might look like this:
Code:AZ04-33:01
But how do I go about labeling the far end? We have multiple wall pla setes in each room, and some wall plates have more than one ethernet cable going to them. We have wall plates on multiple floors.
Channel: Troubleshooting & Designing Networks
11-16-2018, 07:35 PM -
by SluggerBI have 2 LG TV's in a room. It seems the power button is the only IR button on the remote, since pressing the power button on either remote turns on/off both TV's. Once turned on, the remotes only work on their respective TV's (that is a setting I set on each, I gave each it's own ID)
I have "solved" the issue by putting electrical tape over most of the sensor on front of the TV's so they dont pick up the other remote's signal, but I was wondering of there was a more elegant electrical fix that could be done on the board of the remote and/or TV to make the remotes... - Loading...
