Neighborhood Network
  • jpalmer150
    • Apr 2016
    • 7
    So I live 2 miles out of town and have no decent internet service options other than crappy DSL.
    My neighbor is the town Vet and his clinic is located just inside of town. It is serviceable by the local cable company up to 1GB/second. So we want to purchase 100Mb service to the vet clinic and then beam it out to our location and share it with the 5 homes in the neighborhood.
    I also have to provide a secure network to the vet clinic using the same service/connection.
    I'm trying to prevent a bunch of Daisy Chaining but it seems unavoidable without spending thousands for a bunch of stacked switches.
    Have a look at my attached initial design. Does anyone have any suggestions? How would you do it differently?
    • 31247
    Re: Neighborhood Network
    do you have a direct line with nothing in the way? because if you do - TP-Link make long-range wifi kit that will go 50x that range wih the right antenna!
    going the wired route, you probably need to use fiber - but it would be vulnerable if it wasnt underground.
    • jpalmer150
      • Apr 2016
      • 7
      Yes we're erecting two 50' antenna towers and will have direct line of site. I've been looking at the Ubiquiti products, specifically the Nanobeam:
      http://www.amazon.com/Ubiquiti-Netwo...words=nanobeam
      • mariushm
        • May 2011
        • 3799
        Have a look at this product, recently reviewed on LinusTechTips :
        https://www.youtube.com/watch?v=LG-AZz_nm5E
        It's Ubiquity Powerbeam AC ( PBE-5AC-500 ) : https://www.ubnt.com/airmax/powerbeam-ac/
        There's four pages of comments on the Linus forum : https://linustechtips.com/main/topic...istance-wi-fi/
        • jpalmer150
          • Apr 2016
          • 7
          Thanks but the antennas are the easy part. Any feedback on the network design, Routers, Swiches?....any thoughts?
            • 31247
            how's the weather?
            if it's not raining, a laser-link would get the highest bandwidth.
            http://www.tp-link.com/en/products/biz-list-37.html
            those are wifi & antenna combined for external polemount.
            how many ways do you need to split it?
            • jpalmer150
              • Apr 2016
              • 7
              I need to split it into two at the main router and then further split one main trunk 5 more times. Have a look at the documents I attached above. What's your opinion of those diagrams?
              Thanks for the laser tip.
                • 31247
                the split could be done with a simple 8way gigabit router like a TP-Link TL-SG1008 although you probably want something smart / managed to enforce security.
                but what concerns me is the so-called "comercial wireless router"
                what you actually need is a small pc with 4 ethernet ports acting as a gateway & router (and possibly firwall / QOS enforcement)
                because you dont want those 5 houses having access to each other or to the vet's internal stuff.
                and you dont want one user hogging all the bandwidth.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I don't see a need for POE switch on the residential side. As above I'd replace the "commercial wireless router" with a managed switch (a bit overkill) or a small PC running a Linux firewall something like smoothwall or m0n0wall.
                  Replace the POE switch with a managed switch that does VLANs and QoS.
                  • Uniballer
                    • Jul 2013
                    • 334
                    I have DSL. The closest cable company told me I could get Internet service from them, but it would cost me $4700. If I had 4 other homeowners to share that cost with it might be the best way to go (good bandwidth, cable company will maintain it, no radio problems, etc.). Have you investigated options like that?
                    Your equipment layout doesn't get specific about any equipment. I think the "commercial router" at the vet's office matters a lot (e.g. there is a big difference between, say Dell SonicWall and Belkin). It might be better to have two devices there: one that manages splitting the traffic and another that provides the vet's LAN security (he probably has PCI compliance concerns, whether he knows it or not). It looks like you are depending on a mere switch at your end of the radio link between towers. VLANs are good for limiting broadcast traffic and so on, but might not be bulletproof enough for security. But it may be OK depending on the capabilities of the equipment that operates the link between towers.
                    Have you considered lightning protection on the equipment wired to the towers?
                    I would avoid trying to use the 192.168.1.0/24 address space anywhere in your network because so many low-end devices self-configure that way, and even with NAT you could wind up with address ambiguity. Maybe pick something in the middle of the 172.16.0.0/12 block.
                    What are your plans concerning future deployment of IPv6 routing? Unless you get the equipment dirt cheap (used) you should be buying IPv6 capable gear now.
                    Are the homeowners going to select and configure their own routers? Are they aware of the security implications? Are they aware of the possible service limitations (e.g. this might not work well enough in bad weather to allow Vonage to be their only telephone link). Are you prepared to be their technical support crew at 3 AM? What about when they decide that it is unfair that your service is faster than theirs (because you are wired to the inter-tower link and they depend on WiFi)?
                    Are you planning to tell the upstream provider that you are doing this? Or is the vet going to take the heat if you get caught?
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                    • davg
                      Home network connection problem
                      by davg
                      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                      03-06-2021, 07:13 AM
                    • japlytic
                      Maximum speed should be marked on network ports
                      by japlytic
                      I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                      One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                      12-19-2024, 05:04 PM
                    • hikomalek
                      SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                      by hikomalek
                      Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                      When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                      Transformer:
                      |Info| Primary | Aux | AB | CD|
                      |Ratio|1|25|40|12|
                      |Voltage AC|230V|9.2V|5.8V|19V|
                      |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                      I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                      09-19-2025, 03:30 AM
                    • harp
                      simple win network with optimization issue
                      by harp
                      simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                      06-23-2025, 11:01 AM
