please help , I need TP-LINK TL-WA730RE dump
Re: I need TP-LINK TL-WA730RE dump
you could have got it from tp-link!Attached Files -
this is working dump 100%Attached FilesХвала Аллаху, Господу мировComment
After stripping off the 0x200 byte header, I see only the following differences:
This is the header:Code:Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0001FC00 10 FE ED F2 D3 3E FF FF FF FF FF FF FF FF FF FF .þíòÓ>ÿÿÿÿÿÿÿÿÿÿ 0001FD00 07 30 00 02 00 00 00 01 FF FF FF FF FF FF FF FF .0......ÿÿÿÿÿÿÿÿ 0001FE00 34 30 38 35 35 35 33 30 FF FF FF FF FF FF FF FF 40855530ÿÿÿÿÿÿÿÿ
Code:Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00000000 01 00 00 00 54 50 2D 4C 49 4E 4B 20 54 65 63 68 ....TP-LINK Tech 00000010 6E 6F 6C 6F 67 69 65 73 00 00 00 00 76 65 72 2E nologies....ver. 00000020 20 31 2E 30 00 00 00 00 00 00 00 00 00 00 00 00 1.0............ 00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000040 07 30 00 02 00 00 00 01 00 00 00 00 10 1E AC 4A .0............¬J 00000050 39 6D 38 5C E4 69 32 94 A8 E4 AF 1B 00 00 00 00 9m8\äi2”¨ä¯..... 00000060 89 B8 8B 0C CF 91 D0 A1 E0 9D CE 17 32 54 E2 08 ‰¸‹.ϑСà.Î.2Tâ. 00000070 00 00 00 00 80 00 20 00 80 1D 53 F0 00 3E 02 00 ....€. .€.Sð.>.. 00000080 00 00 02 00 00 0D 9A 0E 00 10 00 00 00 2C 00 00 ......š......,.. 00000090 00 00 00 00 00 00 BA EA 00 03 00 10 00 06 00 00 ......ºê........ 000000A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ........ 000001F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
by bealhi
Please bios dump Tplink TD-W9970(EU) Ver 2.0
bios : 25Q64
thanks-
Channel: Troubleshooting & Designing Networks
by corona100i have a bios problem with router after try update from navigator i have an electricity shutdown now this router start and shutdown i need pleas a dump
this is my damaged dump...-
by corona100Hello guys i need a dump for TPLINK TL-MR3420 v5.0 i didn't find any dump for this model s/n 22117J3004396
if someone have vinafix access this is the link https://************/threads/tl-mr3420-v5.45973/-
02-17-2023, 07:55 AM -
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
- Loading...
