Qnap TS 653D - no power / no light / dead
This topic has been answered.
  • EffiSon
    • May 2020
    • 37
    • Sweden
    Got a QNAP TS 653D today, which is totally dead.
    After some investigation found that one of the dc-dc IC (buck converter 568215/ TPS568215) is getting too hot (with NAS own PS).
    Switch to bench power supply and applied the 12V supply to identify the short circuit where found that the unit continuously draws draws 110mA !!!
    Does anyone has its schematic or boardview ?
    Question is how can i verify if that is the only IC which is defective ? is there any way to bypass that and verify the HW before got replacement IC ? where else can i get the similar or alternative IC ? where it is commonly used ?
    Thanks in advance
  • Answer selected by EffiSon at 02-13-2025, 04:41 AM.
    EffiSon
    • May 2020
    • 37
    • Sweden
    Originally posted by mon2
    Flux and remove L20. Be careful to not burn the part with the temp of the hot air tool. After the part is removed, with no power to the board and no battery, measure the resistance to ground on each PCB pad of the removed inductor.
    IC U40 removed, that was shorted
    Resistance at capacitor vs gnd at 1 of inductor pad is 3,5k ohm now
    Which side of the removed component is showing the short condition? What is the exact resistance to ground in ohms?
    No more short after ic U40 removed
    Often, the next step is to use voltage injection of say 1 volt but with high current as available from the injection power supply to smoke out the shorted part. You can use IPA (alcohol) poured over parts you suspect to be shorted where the low resistance to ground will cause the part to heat up and evaporate the IPA faster than non-shorted parts.
    that's my typical method too, thanks
    TPS568215 is a standard part available through distribution channels such as Mouser Electronics; Digikey; Arrow.
    https://www.ti.com/product/TPS568215...secase=GPN-ALT
    This part has been superceded by an improved drop in replaced from Texas Instruments under part # TPS568231
    https://www.ti.com/product/TPS568231
    Thanks, will order sooner
    Your choice to purchase either to replace this switching regulator. However, suspecting that the fault is on the consumer (downstream) side of the removed inductor @ L20 but could be the producer side (this switching regulator) who is shorted. Often are shorted capacitors.
    Yes, its regulator IC, luckily no capacitors this time
    12 volts onto the shorted rail? This is / was extremely dangerous to the board. Always keep the voltage injection to the lowest voltage rail on the logic board unless confirmed 100% otherwise. The reason is that this 12 volts (for your case) can reach the CPU and 100% kill the board. As a general rule, use 0v8 to 1v0.
    Sorry it was my bad if i was not clear enough. I never tried to inject 12 volt on that specific section/block. Injected on the main connector to verify current consumption/short.
    Since the output of the TPS568231, can reach upto max 6V as per datasheet, i wanted to try 4,5V injected to that section, but dont know about the limitations and which signals are feeding back to uC. Any suggestion
    At 110mA current consumption, that is not a short. A short will peak out the max current of your injection power supply.
    agreed but that what i got a constant draw
    • EffiSon
      • May 2020
      • 37
      • Sweden
      Power Inductor L20 and the output of the IC (Output vs GND) seems to be shorted but can't find anywhere else short ? is it due to IC or itself inductor which could be short ?
      Nearby coupling capacitors are all OK/NOT SHORT
      • mon2
        • Dec 2019
        • 13991
        • EffiSon
          • May 2020
          • 37
          • Sweden
          • EffiSon
            • May 2020
            • 37
            • Sweden
            Sorry to re open the topic again. But after long time got a chance to work again on that issue.
            Now the IC has been replaced but still no power. Found that component pins are almost short which has resistance between 45 ohms Can someone identify that IC ?
            • esqmooo
              HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
              by esqmooo
              Hello everyone.
              This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
              Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
              Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
              I tried long pressing on the power button, after several seconds it would go off then when the button is released...
              03-11-2025, 03:57 PM
            • Patan
              Dead LA-H323P (no light) - HP 15-DW
              by Patan
              Need help here...
              I'm new on the forum and I'm not professional in electronics so i ask sorry in advance for eventual errors...
              As title says, i have a LA-H323P dead.
              Now, little background.
              The computer was working fine, just seems that the cable of screen was dying because it had the classic color problem, sometimes green, sometimes violet, sometimes perfect, but anyway working.
              When i opened it the battery was so fat that was seriously near to explode.​
              So i removed the battery... and turned on the notebook... that was, again, working perfectly fine....
              04-28-2024, 03:31 AM
            • Beton
              Finding a dead short component
              by Beton
              Hi guys!
              I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
              So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
              I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
              I have a bench PSU and if I try to inject voltage the voltage...
              12-10-2021, 01:05 PM
            • Rav_tangle
              MacBook Pro 2011 turns on with keyboard light , screen dead
              by Rav_tangle
              Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
              I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
              Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
              is this...
              05-31-2024, 04:09 PM
            • Prott
              Gigabyte GTX1080 - identifying a dead short on vmem
              by Prott
              Hey!
              I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
              I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
              Is there any way to narrow down the search for a short? I would prefer not to remove...
              07-04-2023, 06:29 AM
