looking for netgear WN2500RP schematic
  • gripa
    • Dec 2024
    • 6
    • Bulgaria
    I am looking for a schematic of the netgear WN2500RP repeater.
    best regards
    • 31267
    it probably doesnt exist.
    the datasheets for the chips may have example circuits though.
    • gripa
      • Dec 2024
      • 6
      • Bulgaria
      I found a schematic for the WNR200v3 so maybe it exists somewhere. I have already created a few subcircuits myself. Unfortunately, I can't identify a component that has broken (marking F42A 1K (1K crosswise)) . But that probably belongs in a different thread.
      Furthermore, I have not yet found a data sheet for the broadcom bcm5358ub0kfbg chip.
      Anyway, thanks for the answer
      • gripa
        • Dec 2024
        • 6
        • Bulgaria
        So here are the subcircuits that I created myself. Without guarantee. Among other things, Q3 is broken but so far I have not found out what kind of component it is (marking F42A 1K). Maybe someone here can help me.
        • gripa
          • Dec 2024
          • 6
          • Bulgaria
          a guy told me the component Q3 is the AO6604 mosfet by A&O.
          So I soldered the component in. There is now 1.2 V at the output (pins 4+6). Unfortunately, the extender is still not working correctly. The diodes light up as follows (all continuous):
          D909, WPS: off
          D904, 903, 902, 901, LAN ports: green
          D910, connection to WLAN device: green
          D916, Link Rate 5 GHz: red
          D907, Link Rate 5 GHz: off
          D915, Link Rate 2.4 GHz: red
          D905, Link Rate 2.4 GHz: orange+green
          D906, Power: orange
          A button reset does not change anything.
          So the troubleshooting goes into the next round.
          (updated schematic attached)
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            Have you connected a serial console ? It should be J41 on your picture
            • gripa
              • Dec 2024
              • 6
              • Bulgaria
              No, I haven't done that yet, but I will. What exactly can I do with it then? I have little experience with the serial interface/debugging.
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                You can see if the firmware is running. That would confirm the circuit part is correct, and maybe show some messages of corrupt firmware. Or the thing may be stopping at the bootloader due to said firmware corruption. From the console it is possible ( not always, but many times ) to reflash firmware in this case.
                • gripa
                  • Dec 2024
                  • 6
                  • Bulgaria
                  Ok thx. I have connected my PL2303 TTL USB adapter (GND, Rx, Tx) but I have not seen any messages. Neither with screen, nor with putty or minicom. I also tried with different baud rates and with Rx and Tx swapped at one end ;/
                  So there's probably something else wrong and/or Q3 is a different component, although the 1.2 V output voltage makes sense in my opinion.​
                  Maybe JTAG level will give me some information? I could give it a try​
                  • TinkerTron
                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                    by TinkerTron
                    Hey everyone,
                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                    Instead, here's what's been bugging me so far:
                    The schematic...
                    03-06-2025, 02:03 PM
                  • atunguyd
                    Acer x163w Monitor PSU schematic
                    by atunguyd
                    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                    03-05-2025, 02:08 PM
                  • Thetechdude
                    MSI Ventus RTX 4080 16G Broadview schematic needed
                    by Thetechdude
                    Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                    I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                    Thanks.
                    07-15-2025, 11:15 AM
                  • ianpoultonknights
                    Zenbook Flip 15 UX562AI schematic
                    by ianpoultonknights
                    Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                    06-26-2025, 02:41 PM
                  • Adv10119
                    Need help please! schematic for LA-9982P rev 3.0 (A02)
                    by Adv10119
                    Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                    I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                    I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                    01-31-2024, 01:18 AM
