Netgear JGS516PE Switch Fan Replacement
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
    It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
    Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
    I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
    Instead of spending $30 on the correct replacement fan, does anyone have a clean solution to making the Noctua fan work?
    For now I have put the old fan back and get to listen to the grinding noise.
    • 31157
    the 3rd pin is a minefield - there are several options for it.
    whats the part number on the old fan?
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      It seems your fan uses the 3rd wire for pwm, and the switch expects it to return rpm on that wire. Maybe try with a more "mundane" fan.
      • harp
        • Jun 2022
        • 616
        • Planet Earth
        Or... you can carefully open it, cleaning, lubricating... the particles on magnet inside stator, you catch and absorb with sticky tape... use grease instead oil................. http://www.youtube.com/watch?v=STRnqIjvanU
          • 31157
          3rd pin is not pwm,
          it can be a tacho, or less usually it can be a "rotor lock" signal to indicate the blades have siezed or jammed.
          i have got an AV amp that has this feature
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Originally posted by stj
            3rd pin is not pwm,
            Thanks, it seems I will cough up the $30 for the "correct" fan.
              • 31157
              what is the original fan?
              i can probably find a replacement for under 10
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                OK, so I ordered a "compatible" fan off eBay. Set me back $30. Interestingly they made it work, clearly the wires were soldered together, not the original connector or they buy them without the connector and put the connector on, IDK. But it worked without the fan fault LED coming on and stopping the fan, so that's a win.
                Anyway this is the original fan that was making the grinding noise.
                  • 31157
                  as suspected - 3rd wire is a rotor-lock signal
                  https://www.delta-fan.com/Download/S...0412MD-R00.pdf
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • Tomylee
                    No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                    by Tomylee
                    Sorry for the person who’s going to read all this !
                    I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                    While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                    During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                    07-11-2025, 11:52 AM
                  • Travis Thomas
                    Replacement LED switch for Powercolor Hellhound
                    by Travis Thomas
                    Hey all,
                    So I bought a second hand Powercolor Hellhound Spectral white 6700 XT a while back. The only problem with it is that the LED switch on the PCB is broken. Anyone have a PN I can use to solder in a a replacement? Also, a Boardview or schematic would be good too. Thanks
                    05-11-2024, 09:38 AM
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
