Cisco IOS
+ More Options
Posts
  • luke10050
    • Mar 2013
    • 209
    Cisco IOS
    does anyone have some good reading material for cisco equipment running IOS? have a router i got for a pitance and i was going to attempt to use it. also, any suggestions on reading material for general networking?
  • shadow
    • Feb 2007
    • 732
    Re: Cisco IOS
    I haven't used Cisco IOS for years. At that time I was using the Cisco CCNA text books to learn.
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Cisco IOS
      What are you trying to do with it?
      The manuals that Cisco provide have plenty of sample examples and configurations.
      --- begin sig file ---
      --- end sig file ---
      • AidenGrayson
        • Nov 2013
        Re: Cisco IOS
        CISCO has its own server which works upon the certain protocols and proxies.
        • PLan
          • Nov 2013
          • 7
          Re: Cisco IOS
          There are lots of Cisco router tutorials/books floating around the web, or you can check Amazon reviews - sorry not to be more specific.
          What model router do you have? Note that some of the capabilities will probably be limited by the version of IOS you're running, and new versions may well require purchasing a support contract. Might also be worth purchasing a Cisco compatible serial cable if you're going to be messing around with configuration files.
          • ant3202
            • Jun 2006
            • 274
            • Singapore
            Re: Cisco IOS
            get GNS or PacketTracer to learn some basic ropes
            what do you want to configure???
            • luke10050
              • Mar 2013
              • 209
              Re: Cisco IOS
              i had a look around and my model does require a support contract, its a Cisco 2620XM and i was thinking of using it as a home router if possible, i also do have a serial cable. The router is currently running IOS 12.2, i got telnet and some passwords configured but thats about it
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Cisco IOS
                If this is for home use, you don't require a support contract. You can use it "as is" with the IOS that is on it. It, obviously, won't have the latest security updates or patches, but for home use that might be fine?
                For a home router, the configuration is pretty simple. Something like
                conf t
                int fast 0/0
                ip address 192.168.1.254 255.255.255.0
                no shut
                int fast 0/1
                ip address 192.168.2.254 255.255.255.0
                no shut
                end
                With the above, you are "routing".
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  Re: Cisco IOS
                  I was CCNA qualified in 2003. But barely used the IOS since... Had to configure a VPN for a company last year, and maybe two other Cisco 800 series broadband routers... But the official Cisco CCNA book was excellent, both for general networking and for the IOS. The routing commands are similar but slightly different to the Windows ROUTE command, but the great thing about Cisco routers is
                  a) You have a startup-config and a running-config.. When you have configured the running-config to where you want it, you type wr mem (write to memory) to make the running-config your startup-config... This has the huge advantage that if you mess something up while configuring the running-config, you can simply power off the router and it will return you to the startup-config..
                  b) By typing show run or show startup-config, you can see one page with the whole configuration. This can be copied to notepad and saved. Every time I make a change to a Cisco router I take a copy before doing anything.
                  Back at the time I used a number of emulation programs that allowed you to configure a couple of virtual routers.. this made it easy to learn the commands without messing up anything real ... oh, the fun I had sending ICMP packets around my virtual Cisco network :-)
                  • Hoople92
                    • Dec 2013
                    Re: Cisco IOS
                    Cisco Connection Online is your best bet (www.cisco.com). There are manuals for all of the products, new or old, as well as design documents, White Papers, etc.
                    Good luck!
                    • Rip
                      • Mar 2014
                      Re: Cisco IOS
                      Probably first thing to do is wr t (short for write terminal) will give you the running config. You could always post that and we could explain what it says and suggest any changes.
                      As many have suggested a good CCNA book or webpage is a good way to get started. Cisco also has a command reference that will let you know all the potential commands and their syntax.
                      There is a hump to get over but once you do it will come rather easily.
                      • tightlines
                        • Apr 2014
                        Re: Cisco IOS
                        The 2620xm only came with one fast ethernet port. There is a module that can be installed in it to add a second one. This will be needed to use it as a home router with most home internet setups. It also doesnt have very good throughput (about 8mbps)
                        I have 2 of them I picked up for like $5 each and thought about using them the same way, but ended up buying a 2851 instead.
                        You can get some good information on cisco configuration from ine training videos on youtube
                        https://www.youtube.com/watch?v=bGez...AF9A1586D50544
                        • tightlines
                          • Apr 2014
                          Re: Cisco IOS
                          Also you can use a 2620xm as a home router with only one fast ethernet port is you set it up as a "router on a stick" You will slow the throughput down even more though
                          • Romilis
                            CCNA
                            • Nov 2014
                            Re: Cisco IOS
                            When I was studying for my CCNA I used "CBT Nuggets" It gave me a great foundation to Cisco style networking. Also try and acquire a device running Cisco OS or use a virtual lab such as Packet Tracer as Ant3202 stated in his reply.
                            "Friends don't let friends drink and edit the registry"
                            20 yr IT professional Networking specialist.
                            • mattch
                              • Mar 2010
                              • 121
                              Re: Cisco IOS
                              CBT nuggets is greatvideo series. Seriously watch the whole series and go pass your CCNA. lol. Im using a 2611XM, as my current home router has 2 FA ports, also added a fxs/fxo ports to play with telephony (CME), there is a nugget on that too :p. search google with wildcard for ios file names and you should be able to get up to 12.4 or 12.6 to get the zone base firewall feature. adv-k9 or something like that.
                              • omendata
                                • Jun 2015
                                • 25
                                Re: Cisco IOS
                                Sybex Books are good.
                                CBT is the easiest to absorb.
                                You are only too old when you say you are too old!!!
                                • drpaparino
                                  • Jan 2016
                                  • 9
                                  • England
                                  Re: Cisco IOS
                                  You probably couldn't do much at all with it, except may be practice with some IOS features. But, you will not know if it works because it needs to be connected to another compatible networking device. However, you could set up GNS3 and use your PC as a virtual router or switch.
                                  https://www.gns3.com
                                  You will need a relevant IOS image to install in order for it to work.
                                  • SuperAman
                                    PS5 HDMI port diode reading?
                                    by SuperAman
                                    I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                    02-03-2024, 10:16 PM
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • shadow666
                                    Router Xiaomi M4A Gigabit
                                    by shadow666
                                    hello
                                    i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                    Mi Router 4A Gigabit Edition
                                    ROM CHIP is 16 MB
                                    i attached picture of motherboard​...
                                    11-30-2024, 03:49 PM
                                  • EasyGoing1
                                    UPNP, "Standards" and hardware that implements it
                                    by EasyGoing1
                                    I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                    One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                    So I decided to implement UPNP...
                                    07-16-2022, 07:12 PM
                                  • testaccgta
                                    Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                    by testaccgta
                                    Hi, everyone!
                                    I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                    I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                    09-01-2024, 08:24 PM
