Re: Laptop won't connect to the network
maybe there is problem with the wireless routers. have you tried contacting the technical department of the router vendors? the problem looks like in the baseband part
I run two browsers 99% of the time.
Opera with all extra stuff (java, extensions, plugins, etc) turned OFF for all the forums because I don't need any extras for just viewing text.
Chrome for websites that won't work with extensions or features turned on.
I only use IE for banking as some sites don't work properly in any other browser. After I'm done my banking, I clear all the cache/cookies and close down IE.Leave a comment:
I don't know what it is doing. I closed Internet Explorer (after it was using almost 2GB of memory due to the memory leak that IE has always had) and the weird network activity stopped. Closing the browser usually doesn't stop the activity. It usually doesn't stop until I shut the computer down.
Now that I switched to Firefox, the link speed in Task Manager dropped to 58Mbps.I thought that would be somewhat accurate.
Your computer is doing something with Adobe flash to an external host (not the router). The external host is 67.148.47.71 (some host on qwest's network).
http://en.wikipedia.org/wiki/Real_Ti...aging_Protocol
If you haven't run a virus scan lately, I suggest malwarebytes.org (free version).
My DSL connection is only 5Mbps, so the network connection speed will never be that slow.Leave a comment:
The reported numbers may mean nothing. You can test the throughput of your wifi by doing something like a file transfer and timing it.
Sometimes I run speedtest.net to see how fast my ISP is, but this also indirectly tests your wifi connection.Leave a comment:
If you haven't run a virus scan lately, I suggest malwarebytes.org (free version).Last edited by retiredcaps; 10-26-2012, 11:56 PM.Leave a comment:
My laptop is constantly communicating with the router. I don't know what it is trying to do. Task Manager shows constant 0.1% network usage and the wireless activity light on the router is constantly flashing. I have attached a Wireshark log showing a few seconds of network activity.Attached FilesLeave a comment:
Yes, I am still having connection problems with those two laptops.
I also noticed that the link speed is much lower. My laptop (the only one with a reliable connection) and one of the two laptops with connection issues used to connect at 144Mbps. My laptop now connects at 72Mbps and the other laptop connects at 54Mbps. The third laptop connected at 65Mbps and still does.Last edited by lti; 10-25-2012, 05:13 PM.Leave a comment:
But are you still having problem connection for your old laptop?Leave a comment:
I am already using WPA2, as I mentioned many times above.
Maybe the 3/4" diameter WPS button on the front of the router (no shit) got accidentally pressed at the same time that he tried to connect his laptop to his own router using WPS. This would make his computer connect to my network instead of his. I haven't heard of any way to crack WPA2 (or even WPA). WPS is disabled now, just because the button is so easy to press.
However, considering the amount of network activity, he probably knew that he was connected to my network and was downloading as much child porn and as many pirated movies as he possibly could.Leave a comment:
MAC address filtering is not even considered to be a security measure. Use WPA2 or don't use wireless at all!
http://www.maxi-pedia.com/how+to+break+MAC+filteringLeave a comment:
Now I want to know who Don-HP is and how he got my wireless password.
Time to block MAC addresses...
Update: He's blocked now. I might only allow the MAC addresses of the three laptops on my network in the future.Last edited by lti; 10-22-2012, 03:24 PM.Leave a comment:
Can the old router do the WPA2 or it was not running the WPA2 before? or the laptop WIFI card can do WPA2?Leave a comment:
The "Automatically detect settings" box is checked on the other computer. That computer says that it was never assigned an IP address and redirects 192.168.0.1 (the address to enter the router setup) to 192.0.0.1 (an invalid address).
Here are the router settings:
Security type: WPA-WPA2-Personal (both WPA and WPA2?)
Encryption type: Both (AES and TKIP)
Channel: Auto Detect (can be forced to any channel from 1 to 11)
Power level: 100% (can be set from 10% to 100% in 10% steps)
Aggregation: MPDU (can be set to MSDU or Disabled)
DHCP server: Enabled
Lease time: 1 dayLeave a comment:
Yes, they are both running XP SP3. I might be able to change the channel on the router. The "Automatically detect settings" box is unchecked on one computer, but I haven't checked the computer I mentioned in the first post.
Strangely, my laptop works perfectly, but every other computer using a wireless connection has issues.Last edited by lti; 10-08-2012, 09:05 PM.Leave a comment:
XP SP3 I presume.
Locked on N, there is no fallback to A, B, or G.
Can you change the channel on the router? Could it be an interference/congestion problem in the area?
Check: Internet Options - Tools - LAN Settings - [] Automatically detect settings ? Box checked or unchecked?
TLeave a comment:
Both computers are running Windows XP Professional 32-bit. I am using Windows to control the network connection. According to Windows, I am using WPA2.Leave a comment:
OS?
Using Windows or card supplied software to control wireless network? Most time i find Windows works better/reliably.
Check security protocol(s) and network settings (DHCP). Uninstall/reinstall adapter (through Windows).
TLeave a comment:
Re-cap and then have a ball downloading pornLeave a comment:
by harpsimple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
Channel: Troubleshooting & Designing Networks
by zatara10lenovo B580 change wifi card after this error "unauthorized wireless network card is plugged in. power off and remove it"
bios dump attached...-
Channel: BIOS Requests ONLY!
This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
- Loading...
