Cisco/Linksys SWR2024 with major bad caps
  • mark0x01
    • Jun 2010
    • 3
    I've just pulled out a Cisco/Linksys SRW2024 Gigabit Switch that died with smoke signals.https://www.badcaps.net/forum/images/smilies/pimp.gif
    The PSU was the "smoker", and charred the cap, glue and adjacent coil.
    More amazing were the 11 other bulging cap's on the board's 12v input and several SMPS circuits supplying the lower voltages.
    Nichicon, Stone and KZE ?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Cisco/Linksys SWR2024 with major bad caps
    stone...believe me I know...
    how I know? I acually got the exact same model from goodwill for $20. freezed after a few minutes, sometimes hours of being on (depending on how warm it was)
    opened it up, every medium sized stone was bulged. got some nichicons from here, took plenty of time replacing all damn 22 of them, but it ran in a repair shop environment for two years straight, no longer work there (doesn't exist anymore), still have it, still works, don't have much use for a scratched up to hell 48-port switch in my home lan :P
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Post some pics?
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I will later. Hmm now that I think about it, I got rubycons
        it was actually an early cap, and although it went well....I misjudged on the cap size when I ordered. this lead to some...tight...fitting...
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
