Netgear FVX538 router bad caps
  • ecallenil
    • Aug 2011
    • 31
    Just repaired 2 Netgear FVX538 routers with bad caps. Same caps bad on both boards. Original caps were 1000uf, 16V made by TEAPO.
  • japlytic
    • Oct 2005
    • 2086
    Re: Netgear FVX538 router bad caps
    Welcome, ecalleli!
    Good repair job.
    The bad capacitors appear to be Teapo SC (if that is correct).
    • ecallenil
      • Aug 2011
      • 31
      Originally posted by japlytic
      Welcome, ecalleli!
      Good repair job.
      Thanks. I've repaired DC jacks and things like that before but this is my first capacitor repair. I'm not sure how to tell if they are the "SC" model. The only markings are TEPCO, SZ105°C, 10/05, and A3.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        They are SZ series.
        Need something comparable to MBZ for those.
        Mann-Made Global Warming.
        - Dr Seuss
        • sofTest
          • Aug 2008
          • 361
          Then it's SZ-serie, supposedly ultra low ESR capacitors. What did you replace them with?
          Be a mensch
          • ecallenil
            • Aug 2011
            • 31
            I believe it's a Nichicon HN(M) B1050.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              HM would have been good enough but HN will work fine.
              BTW:
              The (M) is just the uF tolerance code [+/-20%], and not part of the series name.
              .... I know,,, they run it together when they print it.
              - Dr Seuss
                by momaka
                03-15-2023, 10:17 PM
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • ay_erdi
                Netgear R7500 Router Dead
                by ay_erdi
                Hi everybody,
                My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
                VR8-U17-U78...
                02-16-2024, 10:58 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
