ADSL Modem DSL-300G
  • Decade
    • Dec 2005
    • 37
    ADSL Modem DSL-300G
    Lately I've been having a hard time to log on, no one in the neighbourhood had any problem so I decided that the fault was at my place.
    A quick check under the hood showed a bulged TEAPO35V/220uF replaced it and now I go faster than ever
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: ADSL Modem DSL-300G
    good job! routers/modems are usually full of badcaps. not only that though their temperatures are incredibly high.
    • Decade
      • Dec 2005
      • 37
      Thank's!
      Yes they are running real hot inside, there is not much air that pass inside the box, I think it is a common problem with D-link Friend of mine mounted a small fan on top of the cover and got rid of all problems their mains adapters are also prone to fail
      • markiemrboo
        • Mar 2006
        • 44
        That's quite interesting! I think I might open my modem when my caps arrive and see if any in there need replacing or anything
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          it is no problem to recap if you find some bad ones. routers, switches etc, it is much easier than motherboards.
          • japlytic
            • Oct 2005
            • 2086
            Our Billion ADSL Modem/Firewall Router contains Teapo SEK series and one Hermei HV series (3300uF 25V) unit; none of them were bulging since the modem was working for two years, despite running a bit hot.
            • Decade
              • Dec 2005
              • 37
              No wonder they fail now and then these modemes run real hot.
              Have looked in to several of D-links modems but this is actually the first time I've found a bulging cap, seems that better airflow cure many of their problems. Just by open the top cover of my D-link router all shut down problems in my network stopped
              • dahm
                tenda v12 ac1200 modem
                by dahm
                please need me tenda v12 ac1200 modem bios dump 8mb
                05-23-2025, 12:15 PM
              • rbvndonh
                Lenovo T440s 1802 WWAN modem error
                by rbvndonh
                I had factory installed Ericcson modem. It was working, but later was changed into Dell 4G modem. It was working good.
                Now, after BIOS repair (to the same which was rapaired in past in this machine) it shows 1802 error.
                Does somebody have whitelist or know how to correct it or proper no-1802 tool or solution for this board?
                Thank you
                12-04-2022, 01:09 PM
              • playit
                broadband ut300r2u modem,link light stays on forever
                by playit
                ut300r2u modem,link light stays on forever no matter if if dsl phone wire connected or not.i dint mess with any firmware ,it started to be like this for past few months until it stopped all together to work anymore,so learned that flashing might help, need dump file for this modem, i have only ch34a1 programmer.so i erased and flashed with few bin or ras files i got from internet but nothing worked.so further reading let me know that have to flash a whole full dump .if any idea, pls share, thank you.
                08-11-2022, 01:44 AM
              • TheQuentincc
                Dell Precision 7710 no M.2 Wifi AND LTE modem
                by TheQuentincc
                I have an issue with a 7710 motherboard, nor Wifi card/slot (8260AC and 3160AC) and LTE modem/slot (EM7455) are detected in bios/OS, the strange thing is that the wifi card is a wifi/bt combo and the BT is recognized in bios and working.
                Since BT is working I think the power for these card is present, I already tried a few bios for the motherboard (asked on another thread) but only one is working, I got the board with a bricked bios and it's not a thunderbolt version.
                I believe there is either a signal that disable the M.2 slot (all enabled in bios) or wireless...
                07-29-2022, 01:40 AM
              • Thunderace7
                Cooker Hood Repair
                by Thunderace7
                Hi.
                I've been repairing a cooker hood for my daughter and, although I have got it working, I am puzzled by a couple of things.
                I have attached the circuit diagram I made from studying the PCB. It is a bit rudimentary but it served its purpose.
                There is a buzzer, driven by output P0.0 of the processor, and the circuit seems to be a bit strange. The buzzer seems to be continually powered by 12 volts but is short circuited by the driver transistor. Any idea why this should be? I have checked the PCB several times and this is definitely how it is wired.
                The second thing...
                11-02-2023, 09:46 AM
